Vince B wrote:Yesterday I checked the inputs to both amps and their respective outputs with my inexpensive but fairly accurate hand held digital O - Scope. I was not going to drag my Tektronix 465 from my shop. What I found was what I expected. Using a reference CD with various sines waves @ 0db and -10db depending where I set the level on the head unit the AC varied from 0 V on up. Of course the speaker outputs went much higher. If I can remember at least 6 or 7. I was not about to push the system but if I would I'm sure I would have seen double digits. Heck when I repaired pro sound amplifiers such as Crown and QSC those units could easily hit 60 - 70 V on the outputs. On a side note, I have repaired many audio power amplifiers and have never run across a unit that used phase modulation. I have thought worked on RF equipt. that did use it. Finally, about the scopes reference point. In the past 20 years of repairing electronics, I have only had to use a value other than 0 (earth or signal ground) one time. That was when I was working as an asst. engineering technician dissecting circuits that the real engineers designed on paper but when bread boarded didn't work.
You are correct about what you would normally find with peak to peak using 0 reference, but that is not always the case. One example is where you are using a system to detect signal to ground exceedence such as alarm panels. Basically you have a voltage of lets say 10 volts peak to peak with your reference on a floating ground of lets say -1 volt. This leave 9 volts to ground under normal conditions (or +1 to the reference) it either one of these changes you have a signal to ground issue. An alarm will pop up and let you know this. I think you would be surprised at how effective and how sensitive this is. A couple of milliamps on a plant wide grounding scheme will show up. This allowed you to go looking into various panels for something like a drip of water leaking on to a circuit board, etc.
I have worked on several signal systems that use phase modulation but like I posted I doubt they would do so here since others have tapped into the line and put in aftermarket amps. I am thinking there are a few who have then had some issues after doing so without realizing they are not really looking at a normal rca style output assuming the - is actually ground.
What type of hand held scope are you using? I have a small scope and a couple of old large ones but have been looking at getting a hand held. The other option is a pc scope for my laptop.
Perry
