lucidd wrote:"What's important is if the sound is good to the listener.
Unfortunately, this will vary from person to person, but should be within a marketable margin."
Well... this has been bose marketing credo since its inception. Although I do agree that sound is quite subjective - especially when each person "hears" differently... bose has taken advantage of this idea - to sell crap to unsuspecting consumer for years.
Just do some research - a simple google search and filter out the BS bose hyper-marketing and the bose bashing... and you'll get some profound facts about their products. -they don't publish specifications of wattage, freq response etc-on any of their lines of speakers- reason: because of the above: sound is subjective... and should not be judged from their specs - but using listening practice.
So back to the G's system... Just some facts:The 2007 G's and up have the studio on wheels Bose:2 tweeters up front2 3" mids3 10" subs2 6.5" mids in rear doors.
Am I the only one that notices???
OK... I must be the only one.
I noticed right off that in a few areas you are incorrect. It doesn't hurt to get your facts straight. For example they do publish the wattage of their speakers on their website:
201s for example are 120 watts, 301s are 150 watts.
And these are just two of their speakers. Looking at many if not all others give similar results. You will see frequency, wattage, and so on.
For example their MB4 gives a listing of:
Frequency Range40Hz to 300Hz ±3dBSensitivity187dB-SPL @ 1W, 1m (pink noise)Maximum Acoustic Output2110dB-SPL, @ 1m (pink noise)DispersionOmnidirectional at all frequenciesbelow 200HzLong-Term Power Handling3200W continuousImpedance8Ω nominalMechanical SpecificationsDimensions:18.1"D x 10.2"W x 26.7"H(46 cm x 25.9 cm x 67.8 cm)Weight: 45 lb (20 kg)
Some notes:
1Band-limited pink noise is applied to the MB4 speaker and amplified to a level at the loudspeakerterminals corresponding to 1 Watt as referenced to the nominal impedance. The average soundpressure level (dB-SPL) is measured at 1 meter from the speaker in an anechoic environment.2Band-limited pink noise is applied to the MB4 speaker and amplified to a level at the loudspeakerterminals corresponding to the long-term rated power handling of the speaker. The average soundpressure level (dB-SPL) is measured at 1 meter from the speaker in an anechoic environment.3Band-limited noise, meeting the IEC Standard #268-5 is applied to the MB4 speaker and amplifiedto a level at the loudspeaker terminals corresponding to the power handling of the loudspeaker. Theloudspeaker must show no visible damage or measurable loss of performance after 100 hours ofcontinuous testing.
While I really don't care if someone doesn't like the sound, but what I do care about is accuracy in statements as much as accuracy in sound reproduction.
It still comes down to what it comes down to for any car manufacturer, the use of the name Bose, Infinity, Harmon Kardon. Radio Shack, it doesn't matter, it is just the use of a name. As far as small diameter speakers go, smaller speakers do have certain advantages, it is what made the sweet sixteen so popular.
Perry
