Let me give you an example of why I don't think eaton type will fit.Check the link... as you see:
-the pulley would have to face the front of the car where our crank pulley is... no problem here
-the sc outlet would have to face the intake side of the engine (again no problem assuming you can fabricate an intake manifold that would bolt on to sc)
-the sc inlet would face the back of the engine bay... oops!!! How can we fit a say... 3" tube her to curve around the engine with the mafs and throttle body on it, because we sure as hell can't fit all of that in the back of the engine bay the way the motor's mounted now... so surely we'd have to loop around the engine (thus bringing the air filter and mafs to the drivers side of engine bay in roughly the same place it's oriented now) do you get it?
http://www.magnuson-products.com/superc ... sample.htm
I've included a rough diagram just to clarify...I know it's crappy, I made it in MS paint in like 5 minutes...
