[QUOTE]Originally posted by SSDwellah "]No I don't think roots type would work well... consider an eaton type design for example... the pulley would have to face the front of the car and then the custom intake manifold would face the engine (to the right if you're looking into the engine bay) but the intake piping would face the firewall with little to no room... it's not the KA's fault, it would work in an altima because of the way the engine is mounted (90 degrees different), but in 240sx it is more feasible to use centrifugal vortech type supercharger.
I saw an Eaton setup made for a Miata, they installed curved tubing from the rear and goes to the front with the filter. Seems OK, check it out:
http://www.jacksonracing.com/pages/presspass.htm
Something like that could be done for the 240. The ideal thing would be to replace the whole intake manifold with an Eaton conversion...sweeet.
