Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sun Dec 08, 2002 4:52 pm
No, I guess owning 2 and being inside of the engines does not qualify me as an expert, however, I think we can all agree that as a basic assumption, very few engines can handle 20lbs of boost above the standard 14.7 lbs of ambient air pressure. Because it can be assumed that the resulting pressure in the combustion chamber would cause a large strain on the die-pressure casted pistons and cast rods. You see, when a piston is pressure casted, it is similar to a forging, in that it's increased density is it's point of strength, the exception being of course, that since it is still casted, it is prone to having MORE casting failures. This is the weak point of the KA motor, since the block is cast-iron, and the crank is girdled. Nissan has incorporated squirters for the pistons to help ease any damaging effects heat might have, but this would most likely not fix the problems that 20lbs of boost would bring. But then again, maybe you were the first to think about doing this, and maybe I have never researched the issue. Why do you come to a forum when you do not want to learn?
