Gino »
https://forums.nicoclub.com/gino-u21116.html
Mon Nov 30, 2009 6:50 pm
Well guys, quick update...after a closer look at the steering rack we (the shop and myself) have come to the conclusion the rack that was suggested is way wrong. The rack that I was told should work is a front steer rack (front steer means that the rack is on the front side of the cross member). The Z being a rear steer, this will not work. Not to mention the rack centered puts the steering shaft about six inches closer to the center of the engine bay. SO, i talked to flaming river and found the right rack and will be doing an exchange, so that might not be done until next week. My heads are almost complete, upon the initial install of everything it turns out the heads have to be cut slightly for the inner spring. We are only getting .375" of lift out of the inner spring, my cams need .385". We could remedy this by removing the seat locaters, but would rather just cut the heads to accommodate so we can still use the seats.
Also, made a new decision for the exhaust. will still be using 3" expansion down pipes which will have the flange cut and replaced with a v-band, then from there back will be 3" straight pipe exhaust (all v-band at any joints), run through a 3" inlet N1 style (HKS hi-power style) muffler. No resonators, no silencers, just 3" piping and a muffler.
so it's coming down to crunch time. If the d!ck bag ever sends my 2 grand back ill be done as soon as I get it. If not, end of this month should suffice. Once the heads are back everything goes together. I will be shaving/painting the engine bay when she car is back, also. Hopefully some updates this week!
