Gino »
https://forums.nicoclub.com/gino-u21116.html
Thu Mar 25, 2010 3:46 pm
well, another small update lol. I could have had the motor completely assembled, but in all my glory i didn't even think that I used my cam seals when I put the JWT milds in the old motor...SO i had to order new seals. Just got them in, so now I can finally fully assemble the motor!
PLUS...
MY CLUTCH IS HERE! lol After 3 months of playing the waiting game Spec still couldn't build my triple disc. So i scrapped that and placed an order for an HKS triple. An extra 400 bucks and a week later I have it! Harry shipped it straight from Japan, no overnight though. I'll play the tease game
HKS huh? what's that mean?
Sweet! A Piece of paper!
s***..i can't read japanese...
OOO...now im beginning to see...
Even better!
count em...1...2...3!
aside from that, I installed the majority of my suspension bits. All 4 corners have the coilovers installed, I need to do my front camber arms and tension rods, my rear camber arms are installed as well as the hicas delete, BUT i also have solid subframe bushings and dif bushings on the way (so the rear installs were pointless as it's all coming out anyways). I will also be getting S14 front and rear LOWER control arms (adjustable. The S14 shares the same basic suspension as us) so I can adjust my wheel track and have a FULL range of adjustability in the suspension.
I am still working on the fuel bulkhead, all that's left is the return assembly. I am still waiting on some parts from Z1. Ash's dual fuel pump controller is on backorder, hopefully soon. As well as 300 degree triple din is on back order. On the way is another AEM wideband (running dual wideband as the primary O2's on the haltech), two EGT's, and an OPS. I will be cutting my double pod on the A pillar to a single pod..my gauge set-up will be as follows:60mm Greddy boost gauge on the A pillar,wideband's mounted on the AC pod left on top/right on bottom, Left EGT/Oil Pressure/Right EGT in the triple din, all of that is on the way (minus the triple din).
Next up is exhaust, Wilwood brakes, then tune!! So damn close now!
