spockrock wrote:
Well when I did the wiring with mine, I was going to solder and heat shrink the wires, but I thought if I needed to check anything then this method would make things difficult. Grab your self a pack of wire connectors, the ones you twist on to the wires that make a nice and secure connection. Thats what I used and seem to have no issues. Now when you ran the wires through the doors how did you get it from inside the car to the door, I had a hell of a time, Rob suggested I use a coat hanger, gonna try that tomorrow and see if that works.
with mine, they are wired both to one wire (as per the instructions). with getting the wire through to the door, i used what he said to use, the long zip tie, but i zip tied the wire about 5 inches down its length really tight, and just shoved up under the dash until i got it through the hole. as far as the rubber tube goes, i undid the connection on both ends, and fed the zip tie through, periodically pulling the tube at both ends to unjam the flimsy zip tie from getting caught up on the ribs on the inside. im thinking i may wire each light individually to each courtesy light. its gonna be b1tch to get the wire up under the dash tho, i gave it a shot and it was a VERY tight fit. you just gotta keep at it. its a pain, no doubt, and i did hurt my hand trying to get the wire up to the grommet in the first place, but it works.
