Fix Thread turned into Re-build thread! (built rb25 neo)
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
This is what I like to see!
sickness14
Car: 95' S14 SE. RB25 Neo. ARP, Tomei 260's, HX40 Pro, PFC, Synapse, Greddy
thanks guys!
I finally decided what im going to do for a clutch setup.
Exedy Twin Plate Clutch Kit – NM042SD ~$1700. AND ITS PULL TYPE!!!! YES. supposed to be rated for 500 ft lbs at crank. should be plenty. there isnt much lacking in my setup for power goals of ~500 wheel i dont believe. correct me if im wrong. I want this to be a FAST street drivable car that i can take to the track. i hear anything over 600 is where you start breaking s***. i think then i would need a better oil pump. (tomei).
Another thing... do you guys think i'll be alright leaving the cylinder head internals mostly stock besides cams? will this cause any reliability issues with spring pressures, floating valves, ect. i need to figure out whether i want to build the head now before it goes to RLZ for the quench pad repair because they're going to have to tear it down. is it worth going with like a supertech valve spring & retainer kit for ~$400, or a tomei type-A or type-B valve spring kit with separately purchased retainers?
just need to save up some more $$$$ to get it. and then purchase the new fuel system. still trying to decide whether to run twin walbro's or a single bosch 044. twin walbro's would flow more.. but people question their reliability.
this is the remaining parts list from raw brokerage. its going to be tough from here on out because im starting school again in January.
Tomei RB25 Metal Head Gasket (still deciding on thickness, and what about the bore? do i need 87mm or 88mm bore headgasket? im running 87mm piston...)
Nissan RB25 OEM Oil Strainer nissan_rbstrainer Nissan OEM RB25DET Clutch Slave Cylinder nissan_rb25slaveNGK RB Spark Plug Set (RB25DET) ngk_6esISIS Silicone Radiator Hose Kit – RB25DET IS-RH-RB25
Exedy Twin Plate Clutch Kit – NM042SD NM042SDRoss Metal Jacket RB25DET Harmonic Balancer
Deatschwerks 800cc Injectors - Nissan Skyline RB25DET NEO [DE-RBneo-800-6]Greddy RB25DET Top Feed Fuel RailAEM Universal Fuel Pressure Regulator-8 AN fuel feed push-loc, -6 AN fuel return push-locIn line micro filter on feed lineWalbro Fuel Pump Kit s14 OR bosch 044
Modified by sickness14 at 6:53 PM 12/17/2009
Modified by sickness14 at 6:55 PM 12/17/2009
l0nestar
2004 Toyota Altezza
Personally, for that kind of coin, I would go with an STR2CD from O.S. Giken (R34 - RB25 STR2CD) and it retains the pull-style.http://www.osgiken.net/products/strclutch.html
But that's me. Everything else looks good.
sickness14
l0nestar wrote:Personally, for that kind of coin, I would go with an STR2CD from O.S. Giken (R34 - RB25 STR2CD) and it retains the pull-style.http://www.osgiken.net/products/strclutch.html
Where did you find pricing on that setup? Im coming up with :
BNR34 STR2C $2759 (includes pull-push converter kit).
http://www.otomoto.com.au/osgi...e.htm
Is it not a pull type? thats $1000 more than the Exedy! lol
l0nestar
2004 Toyota Altezza
My pricing was direct from O.S. Giken when I was at SEMA last month. I will email you my contacts email. I actually need to email him as well for something else.
Use the link I sent you. You pulled up the street two-disc for the bnR34 (GTR) not GTS-T. (or does the Neo use the R chassis code? I thought that was 26 only)
I was looking at around half that for my R33, but that's also a push style.
Hmm. SPEC does not appear to make a multi-disc clutch for the 26 either..
sickness14
The neo uses the same clutch as the GTR.
l0nestar
2004 Toyota Altezza
sickness14 wrote:The neo uses the same clutch as the GTR.
Hmm. I knew they were similar. I emailed my contact at Giken. Interesting that they list a different part for the R34 RB25 & 26. (both are STR2CD style, but the 25 is about a kilo lighter) I also asked if you would require a push-to-pull conversion.
I'll let you know what I find out!
sickness14
l0nestar wrote:Hmm. I knew they were similar. I emailed my contact at Giken. Interesting that they list a different part for the R34 RB25 & 26. (both are STR2CD style, but the 25 is about a kilo lighter) I also asked if you would require a push-to-pull conversion.
I called OS Giken in cali, talked to sean and he was a cool dude! He suggested the TS1, which is a track inspired street clutch kit that uses a stamped clutch cover, vs billet aluminum. the pricing is around $1700 for that kit. it has a slightly stiffer than stock pedal feel, and will hold 600 hp. Its a twin disc, and needs the push to pull conversion which is $450. Its better than the OEM pieced together conversion, this one is billet and will retain the strength of the pull type trans.
sean recommended that i should contact a place in FL called Billet design and speak with Marco. he has experience with RB setups.
http://www.billetdesign.com/os-giken-m-26.html
Hope this helps everyone in the future. Looks like i'll be getting this setup.
-John
FerrariTruck
wow like the sunroof delete idea., very nicely done. I think im gonna do that as well, never really liked sunroofs. Where can i find the the CF you bought?
sickness14
You can find that sunroof delete kid in the zilvia.net forums under
FerrariTruck wrote:wow like the sunroof delete idea., very nicely done. I think im gonna do that as well, never really liked sunroofs. Where can i find the the CF you bought?
http://zilvia.net/f/interior-e....html
here ya go.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
Im running the Exeddy Twin Disc pull style in my NEO, and I have to say that clutch is an awesome addition..I have not had one single issue wth mine in the three years its been in there and its seen close to 550whp so I am pretty sure you will be good there. Just be mindful of the somewhat fragile third gear in the RB trannies..I had to learn the hard way..now im running a Z32 hybrid in my setup still using the pull style RB front bellhousing. Here is the link in case you are curious about it.
zerothread?id=424884
Modified by S14-NEO at 1:45 PM 12/26/2009
sickness14
thanks man! im debating between the two. the OS needs the push to pull conversion kit, its going to be like 2100 total for that damn thing. hmm. isnt the exedy like 1700?
update:
later
S14-NEO
yeah the Exeddy is a better price, just remember that there is a REASON why the clutch is a "PULL" style on the NEO and well as the GTR...IT WORKS BETTER along with a better feel
Zacho2
Car: RB25 Nissan Laurel
John got my downpipe a week ago or so...just wanted to say thanks and let you know it arrived fine.
Thanks again.
sickness14
Zacho2 wrote:John got my downpipe a week ago or so...just wanted to say thanks and let you know it arrived fine.
Thanks again.
no prob! glad it worked out for you. now for my 3.5" or 4" dp
sickness14
___
Modified by sickness14 at 4:48 PM 12/29/2009
sickness14
Cleaned up the head before we sent it out for welding
-John
BEFORE:
AFTER:
Modified by sickness14 at 5:02 PM 1/4/2010
noodl35
Is that the best they can do? That looks a bit shotty to me. I personally would not put that on.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Wow... if that was my head and i got it back like that i would demand my money back. I would deff. have it welded it up. I looks like some redneck did it in his backyard. Thats no good
boosted98gst
No offense but that looks like complete s***! Anyone that owns a shop that puts out work with there name on it like that will not be around long.
S14-NEO
just remember if there is any sharp edges in the combustion chamber at all, it severely increases detonation...(NOT GOOD)...besides it looks like total a**.
sickness14
The head is now at a machine shop being welded and getting a valve job & surfacing. They'll also set my clearances and CC it so we can get the properly sized head gasket from cosworth or tomei.
Modified by sickness14 at 5:04 PM 1/4/2010
flatrate
Car: S14 kouki
it needs to be welded back up and machined via CNC not dremel
noodl35
if it turns out to be alot of $$$ welding it, just find another head.
S14-NEO
no matter how you slice it, the head is either going to have to be repaired properly and or replaced. With the amount of money already invested in it, wouldnt it be a shame if somethign terrible happend like detonation. from what i can see on the pics you sent me there would no freakin way i would throw that head on my NEW engine SETUP and be ok with it..NO WAY!!!
mott6904
I work at a motorcycle shop that specializes in building engines and porting heads. A turbo 1000 came in about 3 months ago that did the same thing and we fixed it like new, you couldnt even tell if was f***ed up. Let me ask the boss man about fixing this for you. The only thing is you need to ship it to indiana. The only issue i see is that the damage is so close the valve seat. It can be fixed but it could be expensive.
sickness14
Short block assembled, head is at the machine shop being welded. head will also be tapped for oil return drain
Now we're trying to figure out what thickness tomei 88mm head gasket to get. I cant seem to find an answer on how to measure the block & head to determine the compression ratio correctly.
-John
Cjmartz2k
Car: Hunting for a '89 GTR now
Did you get my link?
sickness14
Yea, I joined zeroyon and saw that thread. It doesn't say much so ill have to pm scott
Cjmartz2k wrote:Did you get my link?
sickness14
I was contemplating going with an all out nasty fuel system, and dealing with the Z32 maf maxing out issue right off the bat, but i think ill just get the car running with a single walbro and a Z32 maf and see what power i can make .
after some time, ill upgrade the stuff some more, either with a Ford lightning maf using darius's specs for the pfc settings, or twin Z32 mafs.
It looks like i'll end up going with the Selin dual maf translator, twin Z32 mafs, and a Greddy y-pipe if i can find one. which is REALLY hard to do right now, i cant find anyone that has them.
heres the selin maf translator
http://www.selindesign.net/electronics.html
Then for the fuel, ill probably run twin walbro's in tank with all proper lines. what power will a nismo FPR, stock rail , stock lines support? 480ish whp sound ok?
-J
also found this website, pretty neat concept.
http://justskylines.com/skylin....aspx
