Where is the tension stud located? I don't believe pull type clutch uses a pivot does it?noodl35 wrote:while you have your engine out, i'd also replace the tension stud (some reason been seeing some of those fail) also replace the clutch pivot with a strengthened version b/c i see alot of those fail too!
I may have to get a second walbro then and run dual -6an feeds to a greddy rail. Can I use the two pumps in the tank and have two pickups attached in there? And then have two new lines brought up through the pump cover or something. I guess I need to look at some pics first. If I get an s14 in tank walbro kit it should come with the pump pickup attached already right? Would you run a seperate 10ga wire to the second pump or run both pumps off one wire.Cjmartz2k wrote:That one walbro is going to be pushing it for 500rwhp, maybe not enough. Either another walbro to add to it, or get a bigger pump.
Good call. Sounds like the bosch intank is the way to go.Darius wrote:I have a hard time believing that the tensioner studs just shear off because they are old. I'm betting the tensioner bearings failed causing torque to be transferred to the stud and fatigued it to failure. Does anybody know of someone with a new tensioner where the stud snapped? The shear strength on any bolt is massive, so I can't believe that they just fail because they are old.
I agree that the walbro will probably be near its operating limit, bkut previous conversations have led me to believe that it is theoretically possible based on the pump curve and assumption of 14V at the pump. Either way, I wouldn't put twin walbros in. I'd go with a single Bosch 044. My advice initially is to put the walbro in for now and upgrade all that stuff in the future as needed. Don't bother with the braided lines or fuel rail yet. Wait until you tune it up to max out your current setup, then upgrade everything at once.
Its all good.Coolwhip wrote:for lack of better words, lol. sry
What about NisTune or Haltech? (I really don't know, just throwing out options)I was checking out the Haltech at SEMA at the begining of the month, their Platinum EMS is pretty nice, got to play with one for an R33 RB25 that they actually had there !sickness14 wrote:Thanks!
Also considering selling the power fc to get an aem ems. Do they make one for the neo? I've got one potential buyer for the apexi at $800. I posted a fs thread on here and zilvia. Its actually listed as a wtt power fc for aem ems.
Any opinions should I keep the pfc or get the aem??
As far as the clutch & cam gears, O.S. Giken is now selling cam gears for the RB's for ~$125 ea. as well as their dual-disc clutch kits for ~$1400. I spent a fair amount of time talking to them. I got to use one of the dual-disc clutches, they are smooth and their 'base' model holds up to around 800 HP if I remember correctly. SPEC has improved drastically and has their dual-discs for $800, and it's fully rebuild-able.. and they are only a few hours from you..sickness14 wrote:
I still need to get -harmonic balancer-injectors-clutch- possibly cam gears...
Waiting for shortblock to be assembled and I'm trying to contact rlz about fixing the head but they aren't picking up the phone.
Lonestar, you're always quiet during all the chit chat back and fourth but i must say, you always pull through with some of the best information! haha.l0nestar wrote:
I'm debating heavily between the two.
As far as balancer, Ricky carries the Ross units that are supposed to be :tits:.
Injectors.. that's a good question. need moar info. Are you running gasoline or E85?
Is Kognition making pieces again? I need to find out if he is making the inserts for S13's.
sickness14 wrote:Lonestar, you're always quiet during all the chit chat back and fourth but i must say, you always pull through with some of the best information! haha.
I'll honestly leave the cam gears alone, dont want to mess with the VTC.
I want a streetable clutch, so from what i've heard the twin disc's have a pretty harsh engagement. Im interested in finding out more about this SPEC company close to me.
The balancer would definitely be from ricky. he's the man.
Injectors... ill be running gasoline, and the ones im looking at are the following in the 800cc option.
http://www.deatschwerks.com/ca...d=208
Kognition is in fact making pieces for the S13 and S14, but it seems like they do it occasionaly now, through group buys. I just bought their S14 sunroof delete! cant wait to get it.
Chris, no problem at all.Cjmartz2k wrote:Hey John, I'm doing a little write up on Stec mani's--think I can swipe some of your pictures to put in the thread? They are about the best most detailed pictures out there of them believe it or not.
What do you mean by re-flowed. do they basically drill out the smaller injectors!? wtf. thats ghey. ugh.l0nestar wrote:Thanks man!
I am not sure about the engagement. Personally I was concerned with pedal feel / weight, not engagement. Currently I have an RPS Max (single disc with HD pressure plate) and received a larger left calf as proof.
10-4 on the balancer and gears.
I'm not a fan of Deatschwerks injectors because they are heavily re-flowed, but thats my personal opinion.
I need to get a hold of Kognition when they do another buy on the inserts. (Mine leaks)
that is the best idea yet....When it time to do head work on my Rb im taking it there also. The guy I went to the rock with has a fully built h22 stocked to a 2.4 and his head was done at RLZ. We had to replace the head gasket when he 1st bought it and man that head was absolutly PERFECT!!! and I mean perfect...foreallsickness14 wrote:Thanks guys. I'm going to take the head to rlz engineering out of concord nc and have them rebuild the head properly making it the way its supposed to be.
