sickness14 wrote:He sent me an email last night and said he could get it to me quick if i gave him a little more money. ($55) vs parcel post which would take months. so i elected to do so.
Question for you chris, this manifold fit pretty good on the head? Im hoping all of the ports actually line up with the gasket and the bolt holes as well. i just had really bad luck with the previous manifold and i dont want to go through that again. Is it guaranteed to fit? If you have any pics of yours more up-close than what i saw last time, could you post them?
The wastegate is going to be tricky to pull off. hopefully i can make something work. I may have to cut the wastegate merge off and make something a little different to position the pipes away from the steering shaft and i want to use just the 40mm for now. i still have the flange and tube from the last manifold so ill probably hack the tube off and weld it to the merge to make it look nicely. would you recommend re-circ the wastegate? I was planning on just using a dump pipe. And this manifold is T4 flanged, and i have a T3/T4 precision, im pretty sure this will work right?
I looked at that thread and it's a greddy manifold, which Scott's are a copy of, so it's close, but not an Stec mani.
As far as bolting up to the head, he fit tests every single one to one of my old cylinder heads before it leaves the shop. No pics for me though. It's in a box and should get here in early Nov. I think. About the runners, I'd say they are pretty good. Not perfect, but good. I think the first time I had the mani on, I put it on as it, but the second time, I might have spent an afternoon with the die grinder port matching the mani to the head. It's not perfect and certainly worth your time to attack the thing with a die grinder, but it's not "half the port is blocked" like that other mani you had posted up about. When you get it, I would (a) open up the two wastegate runner ports with a die grinder a bit to make them flow more and (b) port match them a bit. These mani's are thick as hell, and they can take a LOT of grinding material out of them. Feel how heavy it is compared to the other one you have when you get it. Oh, an a T3 flanged turbo will not bolt on to a T4 flange. You'll need to look at a different turbo, different exhaust housing, or some kind of adapter plate. I've seen some on ebay. They aren't the best option in my opinion since it's FAR from a smooth transition going to mani into turbo. O, and leave that puppy externally gated. I love that sound I might have to make a trip down to raliegh when you get yours and hopefully I'll have mine by then so I can show you what we did with it.
Also, S14neo, just wanted to make it clear that we are pretty sure this mani won't work as is on a LHD car. John is planning on chopping the wastegate runners and re-positioning them to make it work. We are just curious how much they will need to be moved.
