HOLY CRAP CHRIS! $200? where do i sign. lol. can you tell me a little more about these turbo's you speak of? Ill get one instead of using my Precision. i can even make money on this deal if i sell my precision for more than what i buy the HX for! Whats the deal with the HX40 vs HX52? im going to do some reading... i want it! are they used? I think the HX40 would be a good match for what i want. Could you price one out for me and i might paypal you the moolah.Cjmartz2k wrote:I didn't know your turbo wasn't dual scroll. Just getting a version of your turbo that is would net you a BIG gain in quicker spool time. Like 500rpm or better kinda gain. I've heard arguments made for better top end power too, but I can't vouch for that. BTW, IF you are looking at something monsterous like a GT40 or 42 or something in between, I HIGHLY recommend a Holset HX52, and I can get you one for under $200 shipped. Just FYI.
Keeping your turbo with an adapter plate certainly is the most economical way of doing it, just not the best performing. You can get the adapter plate now though (it'll probably beat the manifold here) as cheap as it is and when you get everything, you can mock it up and see if it's something you want to do or not. It would also give you an opportunity to chew on it with a die grinder and try to do your best to make it a smooth transition. Also, about split or not, it doesn't really matter since you turbo isn't dual scroll, but I'd get split, just in case for some reason down the road you get a dual scroll T3 turbo you want to put on, you don't have to order another adapter.
BTW, HX40's come in T4 flanges
PS: hope you dont mind me posting this but i can see your manifold!!
I found a really good pic of an HX40 and a cool manifold for another RB on this thread:
http://www.driftworks.com/foru....html
REMAINING TO BE PURCHASED ACL Race Rod Bearing Set RB26DETT RB25 DET ORDEREDNissan RB25DET OEM Gasket KitNissan RB25 OEM Oil StrainerMachine Work on HeadTomei RB25 Metal Head Gasket ( 87mm T=1.5)Deatschwerks 800cc InjectorsNGK RB Spark Plug Set (RB25DET)ISIS Silicone Radiator Hose KitNissan OEM RB25DET Clutch Slave Cylinder
Dont mind the crappy cell phone pics. went by the shop today. they ordered the ACL rod bearings, should be here by end of next week.
TOMEI OIL RESTRICTORS
Modified by sickness14 at 10:06 AM 10/29/2009
