mott6904 wrote:are you have the machine shop assemble your engine or just the block. I wouldnt decide what thickness headgasket to use until the bottom end is back together so you can check piston to deck height. That will help you determine if you need a thicker headgasket. What pistons did you end up going with? We use alot of J@E pistons at the motorcycle shop i work at and lately they have been producing a bunch of junk.
I will have the machine shop do just the honing and surfacing of the block, and balancing of crank. the shop Piedmont custom motorsports of raleigh will be assembling the engine, and checking piston-to-deck height for me to order the correct gasket.
I ended up going with the CP 87mm's.
Im still stuck trying to decide what i want to do about turbo manifold setup. modified stock mani vs 6boost... so much money being spent on this car Do you guys think its necessary to get cam gears when using 260 pon cams and a 26 bottom end on a ross balancer? hmm. not trying to buy things that arent necessary.
heres the list so far of what im looking at. please help if possible
Bearings / Gaskets / Oil Lubrication ACL Race Main Bearing Set 7M2428H/X Nissan RB26DETT (checking availability) Raw Brokerage $100.00ACL Race Rod Bearing Set 6B2960H/X RB26DETT RB25 DET (checking availability) Raw Brokerage $85.00Nissan RB25DET OEM Gasket Kit oem_RB25gasketkit Raw Brokerage $206.00Nissan RB25 OEM Oil Strainer nissan_rbstrainer Raw Brokerage $27.50Tomei RB25 Metal Head Gasket ( 87mm T=1.5) tomei_rb25hg Raw Brokerage $330.00Ross Metal Jacket RB25DET Harmonic Balancer 306201 Raw Brokerage $546.00 Clutch / Drivetrain Stainless Clutch Line for Nissan 240sx ss_clutchline Raw Brokerage $35.00FujiiSPL RB20/25 Power Steering Hose fujii_psline Raw Brokerage $75.00Nissan OEM RB25DET Clutch Slave Cylinder nissan_rb25slave Raw Brokerage $59.00 Fuel & Ignition System Deatschwerks 800cc Injectors - Nissan Skyline RB25DET NEO [DE-RBneo-800-6] Raw Brokerage $585.00Greddy RB25DET Top Feed Fuel Rail (Injector Size: 11.0mm) gdy_ecr33rail Raw Brokerage $280.00AEM Universal Fuel Pressure Regulator (Blue) aem_25-302 Raw Brokerage $193.73NGK RB Spark Plug Set (RB25DET) ngk_6es Raw Brokerage $24.88 Turbo / Exhaust 6Boost Top Mount Turbo Manifold Raw Brokerage $1,250.00Modify downpipe / Charge pipe Peidmont Custom Motorsports Raw Brokerage ISIS Silicone Radiator Hose Kit – RB25DET IS-RH-RB25 Raw Brokerage $49.99 TOTAL PARTS $3,847.10 Optional / Future Upgrades Carbonetic Twin Plate Carbon Clutch - RB Push Type, Pressure Plate Type: Street (11) ACN23210 Raw Brokerage $2,470.00Tomei Oil Pan Baffle Plate TM193034 Raw Brokerage $236.00Greddy RB Adjustable Cam Gear (Intake) GDY_RBCAMGEAR Raw Brokerage $145.50Greddy RB Adjustable Cam Gear (Exhaust) GDY_RBCAMGEAR Raw Brokerage $145.50
-John a.k.a. Neo "the one" with the broken RB lol.
So i have to ask, realistically, what do you guys believe this car will make power wise? with a stroked / bored bottom end, tomei 260 cams, 800cc injectors, .63 trim precision t3/t4 rated for 565 max. ?
