sweet, yeah the inside of the collector looks a little rough but ill try and smooth it out. nice that your parts are here! ill give you a call sometime and talk to you about it. the manifold is definitely heavier than the other one i had. I want rb26 valve covers too !!! ugh. how can i source them? im not sure about the hx40 from goldfarb i havent talked to linda again since yesterday.Cjmartz2k wrote:Nah, it won't hit the valve cover, but it's close. Keep in mind I've got the larger RB26 VC's, and I can clear them (just). I got my turbo and a couple other things from the wonderful free shipping company that is the USAF though, so if you want to test it, you are more then welcome like I said. I've even got the flange and half a dump pipe (on the way still) so you can mock it all up when you get the block in.
Those ports look decent. Like I said, it's worth an afternoon with a die grinder to port match them, and I'd do the inside of the collector at the wastegate runners too and open them up as much as possible. I can't see from the pics, but there was a lot of extra metal on mine that I could chew on. Heavy SOB though compared to the OBX s***, eh?
O yeah, one thing I just remembered about the HX40's, somebody had one that was wastegated like Goldfarb has and they had to chew on the housing a bit with the grinder to make it clear the valve cover, so skip that one like we mentioned. Did they say what size compressor though?
neither one of my heads i got from you have the oil feed at the front of the head for some reason. i still have not identified the head in the pictures... could it be RB20? i dont get it... yeah dude paper cams are the best. straight from korea, they add extra powa. the manifold came with a shortened stud to use in that tight area of the manifold so all should be well.Cjmartz2k wrote:Hey, the oil feed at the front of the head. Is it supposed to be blanked off on Neo heads? Shouldn't there be a hole there? Machine work on the head looks good though. Nice cams BTW
That one stud is going to be a pain in the a**, I remember that. Best way is to do that one first and NOT put the manifold flush against the head at first, then do the rest.
ttyl man
