tg wrote:Looks like the work quality is good and the shop is reputable. I wouldn't go around slandering them for charging you extra to replace an oil pump -- everybody has a bad experience with a mechanic but that doesn't mean that everyone is a crook. If you wanted all the maintenance items changed you should have specified it before they got started.
Modified by tg at 7:33 PM 6/29/2009
i never slandered his name or called him a crook i just said if he is trying to rip me off thats on his conscience and his karma. i just assumed with all of this modern technology that some one would have invented a way to test an oil pump before completely assembling the motor and putting it in the car. whoever invents that device is going to be a trillionare. i just feel like it its a common problem because i looked back at my warranty for my motor and its required to be changed so why else would they require it if its not an issue? but its whatever there's nothing i can do about it now.
tmeyer29 wrote:i agree....you payed him to do a swap....the fact that you gave him a motor with 2 problems is not his fault. lets say you gave him a motor with a smoked valve or something, its not his fault. I think he is being fair. Looking good by the way...should be a whole diff car soon enough
i see what you're saying but try to understand it from my point of view. i look at my reciept and it says 1200 in labor for inspecting motor and bottom end compression testing and installation and whatever else and then he turns around and tells me i have to pay him an additional 650 because something on the bottom end turned out to be broken after he was supposed to have checked it? i mean now i know that there is no such thing as inspecting an oil pump (which is still hard for me to believe there is absolutely NO WAY to know if your oil pump is bad without starting the engine). but it still seems kinda sketchy to me. but whatever i'm not a mechanic so i dont know how these things work. and he did do me justice by not charging me labor for the install of the clutch master cyl and a few other little knick knacks.
