Thanks Wes and Robert, received my ECU yesterday, installed today. On accident, I ripped a huge smokey peelout leaving my apartment complex for the test drive. Lol. You guys rock!! Thanks for the hard work, 250$ seems like a bargain. (Miata upgraded ECU 995$)
rbaze wrote: Just got the ECU today. Just a couple of questions. Do I dis-connect the battery first? Do I attach the wires or leave alone?
There were no directions and I'm not that mechanical.
Thanks for any help you can give me.
Rich
Here's what I did Rich, (cheap-college-kid way untill I buy a switch)1) Disconnect battery Neg- for safety2) Strip a little from both little wires3) Twist wires together (for Stage 3)4) Insert twist into waterproof connector and seal it up good5) Install new ECU (note: plastic knee trim piece [with the light on it] comes off with a good tug, it's held on by clips. It is typically necesarry to pop it off for a minute to access the upper ECU screw)6) reattach kick panel and battery Neg-done
