Basically. For instance the ECU im currently runing in my Q is from a 91 with active suspension. Doesnt throw any codes or act abnormally at all..Q451990 wrote:So you're saying a non-TCS car could use a modified ECU from any 90-95 - that the actual hardware in there is essentially the same, and that the only difference from the factory was the programming? That should make finding ECU cores a lot easier!
Heath
Basically we offer 4 programs and these are what you get on the switcher. Stock, stage 2, stage 3, and valet....maxnix wrote:Wes, As you may recall, I have one of the early 91 octane ones. I am wondering what the advantages are of the later programs. Seems like when I emailed Robert, mostly they seemd to avoid closed loop and ignore the KS. And is the switch on the ECU so the only way without a remote switch to change the programs is to disassemble the passenger side kickpanel? Any information will help, so thanks in advance. Post it to the thread so all can see it.
The switch actually has a cord and if you requested it he could make it long enough so you could install it in your center console. My cord is about 2 foot long and I stuff it above the trim piece under the glovebox so all I have to do is fish it out and turn the dial.maxnix wrote:Thanks, Wes. Think I will stick with the 91 Octane one as switching without a remote switch seems like a pain and Texas summers and who knows what our future fuels will be? I may even drive in CA or AZ again someday.
Thanks to Robert also, again. Still breaking the rears loose on the slow mapping.
The hardware is actually different in the 90-93 vs 94-95 (8 vs 16 bit) but they are interchangeable.. Theres no real advantage of having one vs the other.
drew, if you could reserve one for me. i'll buy it tomorrow just let me know my email is [email protected] thanks a lotDrewQ45 wrote:I haven't followed all the ECU threads as much as I should since getting mine a year or more ago.
Wes, can you tell me what switch options there are? I'm interested in both ends of the spectrum. All out beast and fuel miser modes if available. Will I need to send my ECU back to you or will you just send me a chip w/switch?
Oh, and for anyone intersted, I have 2 Fed std 90-93 ECUs for only $50 shipped.
zerothread/247384
So if you only add one program (turbo or stock) to a later (1994-1995), is it still the same $50 fee?RobertsnewQ wrote:The 90-93 ECU is the only one I can do the full 4-way switcher on. The 94/95 ECU only gets a 2-way (stock and modified) program.
Also, I do have a turbo program that I already developed for someone else that I can put on there if you want instead of stage III. BUT it is still experimental and you will use it at your own risk.
just adding this quote from heath ( from last thread about nico ecu )Q451990 wrote:I just wanted to mention that I finally got to install my ECU that Robert programmed for me a few months ago. I know... slack.
Anyhow, it works great! One annoyance with both of my Qs is that the target idle (I think it's called curb idle in the FSM) that the ECU uses is something like 550 or 600. So in the summertime, sitting in D but not moving in traffic, with the A/C on - there has always been some vibration. Even if you set the Base idle up with the IAC valve, the ECU is still targeting it's program. Except for mine!
We gave it a new target of 700RPM in the "Stage II" program. I drove it today, and it really works nice. Since Robert has already written that program, other members may be able to request it in the future.[/B]
Robert
Heath
Id plan on 3 weeks.KillerAngel wrote:leme butt in for sec and ask what the turn around time on an ECU job would be. Im really interested in one, but school keeps me busy enough to not be able to go looking for an extra 95 TCS ecu... I can live without the car for a certain period of time though.
Also, is this happening now or will it happen in the not so distant future?
Oh I never let the car get really hot. As soon as the temp gauge would start to rise I would pop the hood and turn the heat on full blast. My mechanic said the pin hole was located near the end tanks and the fins. Over time it must have gotten bigger.elwesso wrote:The fact that you let the motor get that hot, the smallish electric fan would NOT have made a difference! You were screwed regardless, sorry.
