Craving4Boost wrote:
how difficult was it to learn how to use? ranging from 1-10, 10 being the maximum difficult.
It really depends on your knowledge of tuning, ROM editing and hardware configuration.
I could probably build my own board using the diagrams I've found on ECCS. However, it wouldn't be because I'm an electronics genius, but rather because I can read instructions and pinouts.
Tuning the 2-step requires some tuning knowledge, so I'd say it would be rated at about a 6.
As far as using the board, if it were already setup and installed on the computer, I'd say it's as easy as a 1.
You push the clutch, hold the pedal to the floor and it does the 2-step. You release the clutch and it goes back to normal.
