pakicoupe wrote:hy guys can someone help me i got my springs put on and forgot about the bump stop but now unfortunately ive lost the instruction paper for them can anyone explain me what exactly to do or Josh can i get another bump stop instruction paper from stillen?? or is there any link available on here that can guide me?...
Modified by pakicoupe at 8:59 PM 3/16/2008
Paki,
You're going to be in a bit of a bind. The bump stop is under the dust boot and behind the spring now, it'll be pretty hard to get at it and be acurate.
According to Eibach, you need to trim 25mm off from the bottom of the stop. This is on the instructions I have.
Warning, if you try to cut the stop while it is on the shiny part of the shock you risk scoring/scratching the shock which, can/may lead to fluid leaks. I do not recommend this approach. If you do, you have to be very careful.
Safest way to do this is to remove the strut, disasemble, and cut it while it is outside.
-- Wind
Modified by windhaven at 4:30 AM 3/18/2008
