Chris GTFO!!!nismofly wrote:
59 mph stock slalom, 350z does like 71 stock, best ive seen for a street car is jic-magic's rx8 pulling 78 on street tires
the Q is a great car in a straight line, but nothing to write home about from a handling standpoint
also weight isnt the only thing that affects handling
That I'VE called you a nerd, or that you've been called a nerd period?Falkdesigns wrote:I can't believe nchopp called me a nerd. That's a first.
i love you too sweetie <3gniknave wrote:Chris GTFO!!!
.nismofly wrote:strut tower bars do little to nothing for handling
a good set of sticky tires, beefy swaybars, and a nice spring and shock setup would do wonders
on ramps fit the Q well because theyre higher speed and not as tight of turns...kind of like a faster road course, much like how the skyline does much better at faster tracks but has trouble on tighter courses with evos, rx7s, nsx's, porsches, that sort of thing...the Q would probably be quite a fun car to take to a more open track, but something tighter would just be for fun
a tighter road course or auto-x and youll definately be discovering some weaknesses
sway bars will do much more for thatelwesso wrote:Chris, im gonna disagree wit you on that, in that a strut tower brace does WONDERS on the Q... Seriously. it may not do much on the lighter 240s, but with a much heavier car it really makes the front end feel tighter. Sure it may not "handle" better, but it certainly is more confidence inspiring....
I'm going to take a picture of the on ramp I was talking about. This was a turn meant to be taken at 30mph, not to mention it was uphill. Read the threads on the Jeff Williams FSTB, everybody notices the difference between not having one and having one as soon as they put it on.nismofly wrote:strut tower bars do little to nothing for handling
Not speculation. I've driven the piss out of both one after the other and back again. Two very different cars. The difference really feels like it's in the stiffer shocks on the 90-93 vs. the softer ones on the Y33. I can't say the same for the 94-96 (except for the active models).Falkdesigns wrote:
Pure speculation on your part. The Y33 chassis is MUCH stiffer, and chassis rigidity plays a HUGE role in handling. Not only is the chassis much stiffer on it's own, but it also comes stock with front AND rear STB's.
I asked because I don't know much about camber and why people go negative with it. So you can take your attitude and stick it. Instead of saying the damn wheel doesn't fit, you respond like your so much above someone who asked a straight forward question. Pretty much why this forum is here. For all I know you're trying to blind the driver in the car next to you by reflecting the sun back in their face.G50 Q wrote:
Do people really not understand why the camber is the way it is? I mean seriously..... thinka bout what happens to the wheel when there is less camber, now look at where the wheel is in relation to the fender with that much camber.. make sence?
LOL!!!!!!redmanfx wrote: For all I know you're trying to blind the driver in the car next to you by reflecting the sun back in their face.
red
That really wasn't directed towards you.. sorry I quoted you, just a general statement, because the question had been asked several times. Thanks for the compliment btw..redmanfx wrote:
Anyway the car still looks good.
red
It wasn't a negative opinion it was an ignorant opinion. He's also assuming i care about how well the car handles. Which I don't.nchopp wrote:
You asked for opinions, you got a negative one, and you go all nutso. Lame.
yah, kinda weird... was it too concise and hard for folks to disseminate? >HAHA<G50 Q wrote:
I do however, find it funny that no replied to Oneton's post.
...Still waiting for the "experienced ones" to answer this post.one ton garage wrote:the problem here is that there's an extraordinary amount of ignorant folks who tend to preach conjecture. My ultimate example actually stemmed from prior experience on this board... when you post a pic of a car with more than -2.5deg of negative camber and/or stretched tires, it's one thing for someone to post something along the lines of "I don't think that looks good personally".. and that's totally fine because looks are subjective, and everyone has different tastes, so you can't expect everyone to like the look you've got, just as you can't expect everyone to like your car's color. But it's quite another thing when someone posts comments such as "I'd sure hate to have to replace tires every month"... or "It must be nice to be rich to be able to afford new tires all the time"... or "I'd rather have my car be able to corner well"... etc...
It's awesome to hear people who have no real experience with either camber or stretched tires spout their ignorance like that. How can you make such generalized, sweeping statements when you never have tried it yourself? Sure, if all you did was run camber, you could easily burn through a set of tires in a matter of 1-2 months of daily driving (I have before in a worst case scenario experiment for the experience), but if you knew what you were doing and made other adjustments accordingly, and actually cared about maintaining your wheels/tires (i.e. check tire wear and pressures 2-3 times a month, which you should do REGARDLESS of whether your setup is modified or stock anyway), you could easily have a set of tires last just about as long as normal. In fact, I'd even go so far to say that I could have a set of tires last longer on my Q at -5.5/-7.5deg than 80% of the Qs out there running stock, simply because those people don't even know how to maintain their cars beyond taking it into a local mechanic when they hear funny noises. for the naysayers: when was the last time YOU checked your tires' pressures, treads, and wear patterns?
ah, and about the whole performance issue.. this one is always funny. Because, has anyone who says that a sliggity slammed and cambered (beyond -3deg) Q can't handle well actually driven one? HONESTLY? you might be pleasantly surprised once you have. i would be willing to bet that my Q, regardless of how much neg camber I set it at-front and rear-would have easily outcornered any of the naysayer's Qs on here. Now if you have a coilover setup with valving balanced to the springs, corner weighted, control arms with heim joint ends or urethane bushings, and stiffer sway bars, then i would most probably concede defeat. BUT, if you don't even have the first bit iota of suspension mods, then isn't it sorta backward for you to complain about how a slammed Q won't handle well, when you don't even know? And then the next question is, when was the last time you even drove the car in a manner that even came close to overwhelming the suspension? (this isn't to anyone specific, but just rhetorical questions meant to evoke some thought)
EDIT: I guess an analogy to this: "And then the next question is, when was the last time you even drove the car in a manner that even came close to overwhelming the suspension?" would be like worrying about your parachute not opening, even though you never have, nor will you ever go skydiving.
You've been a member since... today?!?!? You're still waiting? Perhaps you should read the post by Rex directly above yours, and then work on some patience.STATUS wrote:...Still waiting for the "experienced ones" to answer this post.
Its incredibly hilarious and entertaining how "forum people" automatically disrespect people with a low post count. Does that make people with 1000+ posts, "GOD's" or omniscient?ceningolmo wrote:You've been a member since... today?!?!? You're still waiting? Perhaps you should read the post by Rex directly above yours, and then work on some patience.
Try this... breath deep. Be at one with the you. Now, realize that this is you breathing deep. As you breath, imagine that you are breathing in only blue bubbles...let the impatience flow out of you as you breath out only red bubbles.
Ahhh... now, you should be able to "wait" until you have been a member for 2 whole days before bitching.
Not to repeat myself, but let's discuss facts and actual experiences, rather than being argumentitive towards one another regardless of thier post count or sign-up date.Rex wrote: ... If nothing else, lets get along alittle better.
Rex wrote:Not to repeat myself, but let's discuss facts and actual experiences, rather than being argumentitive towards one another regardless of thier post count or sign-up date.
Yes, but to make it more relevant to what people are doing here... you would assume that jumping off a tall building would ultimately result in immediate death, but then there's plenty of cases where people have done so and just broken lots of bones, or been critically injured, but lived. So that debunks the immediate death theory right there. But it's still apples vs. oranges...Jesda wrote:I've never jumped off a tall building, but I can still predict the dire consequences.
