maineimport wrote:
So in your case, the donor rear-end and your car must neither have ABS.
Nope, my rear end came off a J30, which AFAIK all had ABS (I know the one I had did because of the big empty hole for the ABS sensor at the fron of the diff close to the drive shaft flange). It may have been shorter, but there is no need to shorten the drive shaft in any way. There is plenty of play to begin with. =)
Fact: S14's have front struts and rear shocks.
Also, if you look at Dystopia's avatar ( just up a few posts ), her boobs bounce up everytime FrEaK's Avatar's car bounces in the air. That takes some talent to notice (either that, or I was watching the boobs so intently that I noticed other things moving in sync with them =) ).
