It's my third day after putting it back together, so I want to say that I have successfully done this project since I do not have any CEL codes or drivability issues. I wanted to give some pointers to people that want to tackle this job.
First and foremost, order your part through IOS. Here's the list of things that you will need to absolutely change:
Code Item Qty Price Grand Total
:11812-41B00 PCV VALVE GASKET
2 $7.69 $15.38
:16175-6P001 GASKET-THROTTLE C
1 $3.34 $3.34
:14722-6P100 EGR TUBE GASKET
2 $4.83 $9.66
:14032-6P020 GASKET-INTAKE MAN
1 $4.45 $4.45
:14035-6P001 GASKET-MANIFOLD
2 $39.36 $78.72
:11062-6P001 GASKET-WATER OUTL
2 $2.28 $4.56
:11062-6P010 GASKET-WATER OUTL
1 $2.28 $2.28
:A6440-N7686 HOSE FUEL
1 $49.61 $49.61
:13270-6P010 GASKET-ROCKER COV
1 $22.36 $22.36
:13270-6P000 GASKET-ROCKER COV
1 $22.36 $22.36
:16636-72P00 INSULATER
8 $0.89 $7.12
:999MP-1217HP THREEBOND 1217H G
1 $11.99 $11.99
:14055-6P000 HOSE-WATER
1 $5.90 $5.90
Grand Total: $248.38
Wait until your Fedex arrives before you take anything apart, since I had to wait extra days until they got out of stock items and shipped it.
Go to local auto store and buy a good torque wrench. I had trouble finding one which had sub 10 ft/lbs. settings. You might not need this unless you are doing your valve covers, but it won't hurt. Also buy a whose clamp set. I got one for 5.99 for a whole set with different sizes. Your old clamps are very tired already. Replace them. You also need a big enough wrench to take out the big EGR bolt. Make sure you have it before you start.
Taking apart: Do yourself a favor and go buy a paper tape. Now if you are hard of memory like me, label everything you take out. Every hose you take out should have a number on it with the corresponding attaching point. This will ensure a smooth put back of everything. BELIEVE ME DO THIS!
You need a good pick tool to not damage any hoses that you take apart. Most of them are stuck and no matter what you do they wont budge. So take your time. I got impatient and damaged a lot of them, so I had to buy replacement hoses.
Don't rush and don't work when you get frustrated. Be extremely careful with plugs and connectors that have been around the lower runners and the heat. Anything you touch there will shatter and break to pieces if you use pliers/force. Be gentle. I broke my KS harness connectors and I had to replace it (well it was recommended anyways so why not!).
Clean everything with various ways that are described in Jack's and this thread. Make sure to clean the hard EGR tube in the planum. It sits behind the EGR so you need to remove that and stuff behind it too. I found this pipe to be the dirtiest of them all. It has two holes on it and both of them were 95% clogged. You need 3 gaskets for the EGR system. In the following picture you can see the pipe and how dirty it is. You can see one of the holes up top, which is so clogged its barely visible. I used a dremel to clean this piece.
Be particularly careful to label where the tubes from under the plenum go to. I did not label them, an had a hard time finding their places. Second time around I would just remove the plate housing the hoses and leave the hoses connected.
Putting it back together is straight forward. You may freak out to see your engine that way, BUT once you put all the pieces together, MOST of the hoses align with their place of connection. There is only couple of them that need to be labelled, but you should label them all anyways. It's not as bad as it looks!
What to expect after the job: If you had 2 failed knock sensors, the difference is MAJOR. You can expect your car to breathe better and basically work as new. The sound of your engine working will change significantly. When you start it up, let it idle for a while, and take it easy on the gas for the first couple of days. I have driven about 60 miles in these couple of days with 20 bucks worth of 91. I have to say my gas mileage improved also.
If you need help, you can contact us for more info. That's what I did and it paid off big time, instead of doing it myself and doing it wrong. Just reply to the thread(s) and we will reply.
