Harbor Freight usually has a torque wrench at the $20 (and change) price point.
Consider anything you break a learning experience as YOU are saving a ton of money and learning as compared to some dealer providing on-the-job training at your expense.
The dealer that performed the 60,000 mile service on my Q stripped one of the VC bolts. I had to "tap it out" to get a bolt started when I put mine back together. Also I found the bolts located at those hard to reach places (near firewall) were basically finger tight.
Note the dealer didn't bother to clean off the factory RTV before installing new. Somehow I don't think RTV gets better with age..
You can see the half moons I removed have a combination of blue RTV from the factory and some brown from the dealer. I have the dealer receipt and name of the mechanic that apparently doesn't bother to clean off old RTV. Ha!
See some pictures from last fall about "Half Moons from an Half Azz Job".
ALSO, the mechanic didn't bother to remove/scrape the old RTV from the VCs before smearing on some new.
