svard75 »
https://forums.nicoclub.com/svard75-u133637.html
Fri Sep 27, 2013 1:40 am
What codes did they read? All three of these sensors are hall IC type which is basically sensing the speed and position of the camshaft/crankshaft using magnets. If you trust the shop I say go for it but make them write down that amount and you sign off on it. It's labour costs. To replace the camshaft sensors you have to take the entire plenum assembly off. To replace the crankshaft you need to get under the car (it's near the oil pan on passengers side). Plus they need to clear the codes and test. I'm not sure of the logic behind replacing all three. The codes should be the key. Jump over to autozone and have them read the codes then post them here.
For example Camshaft are p0340,345 for phase meaning the square wave distances are not in sync with the two camshaft and crankshaft. The easiest is to replace all three, however they have to see if there are bits missing on the existing sensors because those bits can get stuck in the sensor gaps on the camshafts mucking up readings with new sensors.
