[VIDEO HowTo] Infiniti V8 P0340 & P0335. Camshaft and Crankshaft Position Sensor Codes
EdBwoy
The common starting issues, stumbling, sluggish, stalling or dying issues sometimes when warmed up.
[Please get your codes read and present them so we can accurately and effectively diagnose the issue]
This guide should be valid for all Nissans that used the VK45DE V8 engine.
  • 2003-2010 M45
  • 2002-2006 Q45
  • 2003-2008 FX45
And here are the part numbers for the sensor that will address P0340 or P0335:
(The OEM Nissan sensor is the preferred replacement, according to user feedback.)
  • Nissan part # 237314M50B
  • Autozone # SU5745
  • OReilly's # 23731-4M505, 23731-4M506
  • Advanced Auto Parts # 180-0397, CPS0001
The v8 has its cam sensor at the front of the engine. Although I correctly identified the one you are looking for, I erroneously mixed some sensor names in my first post. Below you will find the correct terminology from the FSM.
Here's a picture from my 06 M45 engine replacement. I hope it helps illustrate where things are.
1. Intake valve timing control position sensor
2. Intake valve timing control solenoid valve
3. Camshaft position sensor (PHASE)
These 2 are from my 2003 M45, but the timing cover layout is the same for the 2 generations. Note the green insert that is on the y34 harness.
I see these threads pop up often enough that I wanted to make a video when I got a chance. While doing my jackstand alignment yesterday, I saw a good opportunity to do just that.
Ilya
Good stuff!
EdBwoy
Thanks Ilya, doing my part to give back.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
that's a lot of sensors on them V8
jhuerto23
Car: 2006 Infiniti M45
My wife's car is showing code P0340. I bought the sensor and replaced it as shown in your diagram #3. I reset the ECU using my obd2 reader. Drove around and the code popped up again. What else can I do to fix this problem. The car has died on us once and we had all my kids in the car. It was not a good feeling. Any advise would be greatly appreciated.
Thank you,
Jeffrey
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
Yeah, couldn't be more explicit. Maybe I should add that it's usually advisable to use the oem sensors.
EdBwoy
True Costee. I prefer to keep an OEM spare in my car. Sometimes it's easier to get an aftermarket one to limp along, although I've had good results with Autozone sensors as have others here.
Jhuerto, where did you get your replacement sensor? What I would do is swap that sensor with the one located under the car to see if the car still starts. If you get a crankshaft sensor code instead of the camshaft one, then you know the sensor is bad.
*clean the contact surfaces before installation and secure the harnesses (the plug will click when fully seated)
** be careful not to drop the sensors
jhuerto23
EdBwoy wrote:
Wed Aug 02, 2017 10:49 am
I bought it new from Amazon and it was an OEM part. I went ahead bought another one to replace the other one that's near the transmission. Hopefully this will solve the problem. I will send an update next Tuesday.
EdBwoy
Looking forward to an update on your findings.
To be clear, I meant that I would take the new sensor you put at #3 and install it under the car. Then take the one under the car & put it at #3.
The one under the car typically does not have anything to do with p0340, and my suggestion was for troubleshooting purposes.
jhuerto23
EdBwoy wrote:
Wed Aug 02, 2017 12:19 pm
Thanks for clearing it up but I went ahead and ordered another one. Hoping it will fix the problem. I will update once I get the part installed.
Thanks,
Jeffrey
16volt
So I am getting a P0335 (2006 M45), I already did the cam position sensors (#1) so I assume its the crankshaft sensor. From the reading its underneath the car, any pics or a diagram? (travelling so I dont have the FSM installed). Thank you.
16volt
Think I found it - rear passenger side above the oil pan, that right?
EdBwoy
Yep! P0335 is the crankshaft sensor. Not sure if you've got a chance to watch the video, but you got it, it's the only sensor at the bottom of the engine - where the transmission meets the oil pan, pass side.
Side note: there is only one camshaft position sensor. It's at #3
16volt
Guess I am changing in the parking garage at work when I get done travelling...sigh. I assume you need to drop the belly pan to get to it?
re:cps sensors, i replaced both #1's in the image. Nissan really makes things needlessly complicated with their terminology.
16volt
And the #3 sensor is interchangeable with the crank sensor?
EdBwoy
16volt wrote: And the #3 sensor is interchangeable with the crank sensor?
Correct
16volt wrote: I assume you need to drop the belly pan to get to it?
Maybe just the small rear one if you still have it. I can't confirm right now because I've been staring at the undersides of too many vehicles recently and the individual layouts can get a little confusing.
Jack the front right wheel to see if yours is exposed. You could probably see it just by lying on the ground and peeking behind the wheel.
16volt
Just wanted to say thank you - replaced the crank sensor and the M45 is back in business.
EdBwoy
Good, glad to hear of such outcomes.
And seriously, thanks for following up and posting here. That's the stuff that keeps this place going.
16volt
Welp - it threw a new P0340 Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor). I assume it wants the sensor in position 3?
EdBwoy
You read correctly. That's a good place to start
16volt
Wow - I am now on my 2nd crankshaft sensor (genuine Infiniti part) in 6K miles....anyone have this happen?
EdBwoy
16volt wrote:
Wed Aug 29, 2018 5:38 pm
I haven't but were you able to get a replacement through Infiniti's 1-year warranty on OEM parts?
