mgary wrote:JNKAY41E43M001632 I cant remember the code, I believe it was P0340 or P0430. It was the cam sensor failure bank 1. Strangely, this car was not part of the recall.
Fine. I've dealt with this issue in an earlier post with regard to the M45 2006--which incidentally has the same engine configuration as your 2003. The code you pulled is P0340.
Somehow all these codes are related:
P0011/ P1140:Intake valve timing control position sensor Bank 1
P0021/P1145:Intake valve timing control position sensor Bank 2
P0335:crankshaft position sensor
P0340:camshaft position sensor
Nissan/Infiniti interchanges the names of these sensors (Camshaft Position Sensor, Crankshaft Position Sensor, and Intake Valve Timing Control Sensor (IVT or VTC) depending on location in the vehicle. They are all identical and so are their part codes.
Camshaft: 23731m & 23731MA
Crankshaft: 23731T; 23731TA; & 23731U
IVT/VTC: 23731Y
For your car, there is only one camshaft sensor and one crankshaft sensor. It seems too that what you changed was the bank 1 IVT sensor, and so the problem and error code stayed on. Now, even though you have an error code for the camshaft sensor, I'd suggest you replace the crankshaft sensor as well because usually a weak crankshaft sensor could make the camshaft sensor dysfunctional.The interesting point is that both have the same part number
23731-4M50B (old number was
23731-4M506)The camshaft sensor is located in the engine bay under the air box (intake air duct), while the crankshaft is under the transmission. Because of the interchangeability I just mentioned, the parts are likely to come under the name crankshaft sensor---why not, it's the same part number; what's different is the part code, i.e. the location of the parts in the vehicle.
I'd advise you use oem sensors. Good luck.
PS. Perhaps I should add that the part number for the two IVT or VTC sensors is 23731-2Y52A (new) or 23731-2Y524 (old). It might come as camshaft sensor from some dealers.
