boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sat Apr 12, 2003 10:27 am
Quote »are the smurfs really after me for my DNA?[/quote] Hmmm, have you seen them or did you sense some conspiring on ALJAZEERA:D My observation of the SR's is a motor that when something goes wrong, it doesn't stop (ie blowing a headgasket or a piston). Lean out the SR and you can (most of the time) kiss that shiny block goodbye. Lean out the CA, clean up the cylinders(s) with a light hone, put in used piston and a new headgasket and rod bolts and keep going. The only SR powered 240 I've seen on my end that seems to be holding up pretty well is the one I recently did for one of my friends and the only reason I did it for him is because he used the fuel management that I chose and that's an SDS. Did a 240 with CA18DET and sold him an SDS efi+installed it and I haven't seen or heard from the guy since he drove away with the car (another satsified customer). The Sr's I've seen with JWT stuff or the infamous haltech seems to be the drama queens, but that's just what I see in my neck of the woods where SR powered vehicles are in abundance mainly FWD which are all garbage. You wanna have some worry-fun where you can rev the engine silly and can drive around day in 3rd gear, then the CA's the way to go. But if you want to just have someone throw something in and get some good street power and some good low grunt, then I would say spend your money on the KA24DE(T). But if you must have what Johnny Tran wanted for his civics so he could have the edge at racewars, then the famous SR20 is the way to go. Good luck chosing and happy boosting:help This picture might be the ruff product of a CA18DET/240/SDS install, but this customer was so pleased with his car's performance, he has not come by to let me fine tune his car and dyno it. I just love it when this happens! And as for the SR guys, well, I've seen alot of disappointed faces.
