breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Thu Jun 04, 2009 3:00 am
I think this is the weekend, weather permitting.
I have Zombro at my house and his new heart about 10mins away.
I am making text of what I will be doing per my notes and then I will fill in later with the pictures of when I do it.
On 2wd it is easier to remove the motor with the transmission. On 4wd it is recommended to remove the engine without the transmission.
So after starting the motor and it sounds good. I will begin removal.
1. Remove the hood, held in place by four bolts, mark the hinges for easy alignment later.
2. Disconnect and remove the battery.
3. Remove the Air Cleaner Assembly. I think it had 3-4 hoses attached to it.
4. Drain Coolant from the radiator and the motor block. On the drivers side of the radiator at the bottom is a drain screw.
5. Drain the motor of oil.
6. Drain Trans if necessary, parts car has no Trans and the fluid in Zombro is brand new, I may skip this.
7. Remove upper and lower radiator hoses, inspect for wear and replace if necessary.
8. Mark and label wires and vacuum hoses, then Disconnect them.
9. Remove fuel lines and plug them.
10. Remove A/C compressor from the motor, leave it connected to the piping and be careful not to bend the piping.
11. Remove power steering and leaving attached to its piping. Loosen the tensioner on the belt and slide off.
12. Disconnect the distributor from the coils.
13. Detach throttle cable.
14. Detach Brake Booster vacuum and put it out of the way.
15. Disconnect the heater hoses.
16. Disconnect the alt wires and starter wires.
17. Remove the radiator and shroud.
18. Remove the primary front drive shafts.
19. Drop the front diff so it rest on the crossmember.
20. Unbolt the down pipe from the exhaust manifold
21. Chalk the trucks wheels and disconnect the E-brake, put it out of the way.
22. Mark any remaining wires or hoses before removing.
23. Unbolt Trans from the motor.
24. Attach chains/ hooks to the lift brackets.
25. Take slack out of the chain.
26. Remove the bolts that attach the rear mounting member of the front differential to the frame. Remove the bolts that attach the front engine mount bracket to the engine block. Leave the insulator bolts alone.
27. Lift slightly, separate and bring forward to get the motor off the Trans.
28. Makes sure nothing is connected or hanging up and carefully remove the motor.
Modified by breadbox at 9:11 AM 6/5/2009
