D1dad wrote: ↑Mon Aug 12, 2024 3:06 am
Or in the flip side maybe the engineers figured out that the cvt temps getting hotter is a cure for what ailed them? Death to motor oil, especially here in the north is cold. Oil temps never getting hot enough to burn off water and fuel is typically worse than heat.
People are probably tired of hearing me say it, but everything in engineering is a compromise, especially when you're trying to build for a nickel what any schmuck off the street can build for a dollar. In this case, I just think the wrong compromises were made long ago in the initial thermal design. If they'd installed a large beehive with positive thermal control in the first place, problems like this would never have occurred, the transmission would come up to optimal temperature and stay there just like the engine does. The fact is, thermal management was an afterthought. The ECM's not being programmed to turn the fans on when a transmission overheats tells you everything you need to know. They never expected the trans to
need thermal management, and now they're stuck with a system that can't adapt and costs too much to fix.
But most never used the dealer for standard maintenance so they didn’t have the chance with owners to push it.
That's the rub. Per my convo with our TSM, Nissan seems happy to assume that every customer will visit the dealer for service, and that every tech will trouble to boot a (hideously slow and cumbersome!) Consult3+ and check the fluid deterioration. Sadly, that ain't the real world.
