doctorchee »
https://forums.nicoclub.com/doctorchee-u41751.html
Fri Nov 23, 2007 2:07 am
Hi All
since sometimes that i update this thread. have been doing some update at the 180degree thread instead.
As such please find below some updates:1) engine install and running with stock - complete2) radiator - complete3) exhaust - complete4) turbo, BOV, wastegate install - complete5) manual conversion - complete6) 180degree exhaust - complete (not yet test run, no sound review haha
uncomplete1) water intercooler tank.2) firewall -2weeks time start3) DTA P8rpo stand alone ECU - after firewall (stock in hand)4) test drive5) full roll cage 6) upgarde clutch (no money to buy)7) brakes upgrade 6pf+4pr (stock in hand) 8)rims and tyre upgrade (no money to buy)9) body kit10) paint work
below is some photo update, i have change the throtte body to 100mm and put it in front to create more plenum volume, never see any do that before, however, not sure it will have problem a not and also does it help?
please anyone out there who have knowledge on this please chip in your ideas.
Bracket for the water intercooler.. you can locate it? we did this because there will be less movement if you attached the water intercooler to the engine.
Me, just showing off my proud water intercooler design by me and hand made by the shop - 2in1out
TB extend in front for more plenum volume, please someone there me if this works? or it useless etc.. i have no technical idea for this except i know it looks like increase the volume. advantage? disavenates? more lag? etc.
water intercooler in space. try to make the shortest piping if possible. however, the turbo to the water intercooler inlets is a bit far... mission fail a bit...
V mount radiator. custom made. but the angle will be lesser than that in the actual mounting. a smaller radiator will be in space on top for the water intercoller. huge water tank will be made and place on top of the rear seats inside the cabin. with a lip to put in ice.. for drag time
some other view
some other view
piping and turbo in the back part
future plansEngine currently stock, will be boosting the min 0.8bar for a while. A VH45 crank will be in after my budget permits again, together with cams, valve spring, head works, ports, 9:1 piston, head stud etc.. than 1.6bar (should be bad enough to drive than)
ok so much at the moment. hope its useful information for the others who plans to turbo the car. yet to drive, but i am sure the result would be good. but for sure its not a easy thing to twin turbo the VHs...
winner is the one enjoys the race most, not the one who cross the line
