Hi Alldoctorchee wrote:My new plans. cut firewall..
Should have thought of that long time ago. I only recall this idea when I see the other car around...****...
drifting is a little different as the cars are designed to get zero traction ... so the load on the gearbox is no hassle. put a solid centre 3 puck (drag style) clutch or a twin/triple plate with a big set of slicks and see how well the box holds upMettler wrote:Ezekial, please refer to the d1nz forums for further information. All the top drift guys here with RB26 & RB30 powered S13s, Cefiros & Laurels are drifting these gearboxes and running high HP numbers (over 500HP), and I've spoken with a couple of the guys who say the trans is mint !
As riu said, it's all how you drive. Powershifting, flat shifting etc, that'll root any gearbox after enough time... but if you treat it with respect, give the synchros time to engage, and aren't generally rough as guts, the box will last. The teeth are strong enough to withstand the torque at least !
I will be doing a new firewall or rather a cover for the engine.elwesso wrote:The motor is literally gonna be in your lap!!!
Thanks for the encouragement.......I felt the project is getting way too much and I feel it may have a lots of problems coming up.... but since I am halfway through, I will try all ways to finish it...Ezekial wrote:Cut firewall ... interesting ... looks good!!
It is like sychronized swimming for for wannabe racers.Ezekial wrote:drifting was old the first day it showed its ugly face
I dont know where you got that from but doing this is cake. Cooling wont ever be an issue. All he needs to do is build a tubular subframe around the engine and hes done. Turbo manifold can now be directed to the front of the engine, and he can place it lower if he uses a dry sump.maxnix wrote:It is like sychronized swimming for for wannabe racers.
Moving the engine back is a great idea, but you will need to serioiusly re-engineer the comprmised firewall. I would suggest considering a dry sump like Dixon as the <6 qts. of oil will be sufficient for turbo application. Cooling will probably be problem, also. I would forget NOx if you want your engine to live more than a few runs, especialy at 150.
When you say you can't afford the strong transmissions, I would say you are at the limits of your budget for a project of this scope. To do it right, lots of cash required or your own extensive automotive engineering knowledge and your own first class race shop. You will be spending lots of money even after it is all together.
The Z32 trans has the same gear cluster as the GTR box. I don't know whether the GTsT does actually use the GTR cluster.Yes the z32 box is very strong. I have 2 mates using them (make that 3), one drives like an idiot and has 406rwkw and one very noisey gearbox after years of abuse, also flatshifts and uses lanch-control at the drags. He hasnt broken one yet and drives on the road with race tyres. The other one has apparently got 500rwkw, but I saw it do 480rwkw about 1 month ago in tauranga. He hasnt had any crunch issues yet. The z32 boxes do **** synchros if u race them hard, but i havent yet heard of one going bang, and teh z32 is now the car that i know most about.As for the celica/supra boxes, I have used those over the years. I believe the celica to be good for around 300-350hp, and the supra to be good for 400hp+. I think 500hp is being optimistic if its 500 V8 hp. Great box though at only 35kg dry weight, lighter than the celica one at 45kgs. I mean the 80's supras as well. The new 6 speeds, ie 93 onwards are supposedly great but I dont know much about them, but from what I have heard they are like twice as strong as the old supras. The Z32 box is 55kgs, but worth its weight. I am using a GM T56 box in mine. Hopefully i dont blow that. If so I have a spare z32 box, but doubt whether it would be quite as strong as the t56. Similar size externally. T56 is approx 58kgs.Also dont even bother loooking at the z31 box, they used the T5, and not even the tougher t5.Also the Z32 TT and NA use BASICALLY the same box, with a few differences (according to the fiche i have) but strengthwise yes the are equally strong, and run the same gear ratios.mtcookson wrote:Isn't the GTS-T box the same used in the Z32?
This setup is like that guy from the middle east who made the 4 turbo mercedes v12 engine in his nissan skyline. Here http://img.photobucket.com/alb...1.jpgh ... lb...6.jpg
Honestly if you can make a roll cage and build guessets you can do this. Triangulation and torsional stiffness if you dont know the basic use of the triangle then I'd be worried.
