Thanks a lot. sorry if you don't mind, this will be the first time I will set up ECU myself.Mettler wrote:Hi doctorchee, I recommend learning to resize your pictures :p
Also, the stock ECU is 32 bit and very powerful... if you purchase a pocket romulator, pocket programmer, and a couple of chips, you'll have all you need to write your own mapping for every aspect of the engine management, at 1/4 the cost of an inferior aftermarket ECU.
as wes said ... i would modify the sump and if possible have the volume at the rear. lowering the cross member can change steering geometry dramatically.doctorchee wrote:1) the engine oil pan hits the crossmember and power steering2 ways to solve it, put a spacer at the crossmember or modify the oil pan please suggest the advantages and disavantage of the 2 method. Personnally, I prefer to lower the crossmember
riu wrote:A Z33 350Z 6 spd transmission should work with an adaptor plate with the VH motor.
Q45tech might know the answer to this.
Thanks for the advise. I will look into this. Can you advise if is it better to custom make a whole new oil pan or modify the exisiting? Is there any aftermarket avaible? ....(doubt it will have)elwesso wrote:Yeah a Z33 MT would probalby be the way to go... Because you can then (I THINK) use the Z33 MT flywheel which then means you can use a Z33 clutch...
Thanks. I should be going into this route. If the gearbox is strong and not too ex. .Can check how much can the Z33 gearbox take?
Regardless you can get Mettler's VH41 flywheel, make your adapter plate and go from there...
Will see how from getting the box first. U
To be honest with you, you really need to take it one step at a time. Get your stuff running in the car with the trans with a little bit of boost, and then go from there..
Yes. I totally agree with you. Getting too many things to work together at 1 time is difficult. Especially when you have problem, you don't know where to start from.
Its possible your idling problem is due to the injectors... Just check the ECU codes.
Does anyone here have a ECU pinout and ECU codes??? Thanks so much.
There wasnt any AWD VH41 I dont think... I dont remember if the J. Ferie was AWD or not, but I dont think it was... You might be better off finding an ATTESA system from a skyline and making it work on your project...
To be honest, I am just toying the 4wd idea. But if it is not too difficult and to ex, I will do it. But I don't think any 4wd conversion is easy and cheaphttp://www.cars-directory.net/...998_9/
Mettler is right, you can control about anything you need with the ECU as far as engine management... However if your doing so many things with nitrous and all that crap you may want to spend big bucks on an aftermarket... Its hard to say, but it sounds liek you need to control a lot of things and itd be hard to make the stock ECU do it... Its POSSIBLE to make the ECU do it, but its harder..
Thanks a lot. I may consider doing the cheaper way. I am not rich. I will be studying and reading up on modify the ECU. If I feel confident, I will do it.
If you were just running some boost with bigger injectors, for SURE id still use the factory ECU...
ya.
I think your engine should handle the boost you want but plan on getting bigger injectors... the NISMO 555cc/min injectors should be fine...
Can I check is the side feed injectors same with SR20DET and RB25DET? Direct drop in?
as far as the oil pan, id modify the oil pan personally.. its only got 6 quarts and its made for street driving... Oil starvation on a high HP car running through cones is a concern!!! Either go with a high capacity rear sump or a dry sump.
maybe I will go with standard 370cc with extra injectors. (1000cc x 2) run in staged. worry about bad idling with big injectors....Ezekial wrote:as wes said ... i would modify the sump and if possible have the volume at the rear. lowering the cross member can change steering geometry dramatically.
Ok I have yet got time to go and discuss with my mechanic. however, I have decided to modify the oil sump to rear type. I will go shallow in the front to clear the crossmember and wild in the back.
once again ... as wes said. check injectors. AEM has alot of support in USA i believe ... however there are cheaper alternatives available. Microtech, Autronic, etc
Ok. Thanks. I will check the injectors. But I like AEM is becuase of the functions like - traction control, lanuch control.... U - power is nothing without control.
I've heard the rumour they came in 4wd. dont waste your time
Ya. SAve time
well x1 normally makes 300-320 rwhp on an FJ20 or SR20 so this would be a good choice. And relatively cheap check intake closing angle for VH41 and then see if you will be able to get away with 1 bar (15psi)
Ok. decided T3/T4 from Ebay. only about 200us new.
I know it doesnt have vvt so closing might be 48 not 68 in which case you might be pushing it. Or just get a nice set of billets or regrinds
VH41DE don't have VVT ? I though they have it? or just VVT on the out, in don't have? Where to regrinds and how much? how about billets?
as above. check cam profiles first. if you are going to run standard camshafts then possibly run 8.5. if you are not going to get longer duration camshafts keep the compression as isok
you wont need nitrous with 2 turbo's just like to play nitrous... have not use it in my life. so must do it.
nismo or sard. go 850 cc injectors.
The stock hardness and ECU is in place when I brought the engine. However, there I did not buy a half cut. As such, some sensors seems to be missing. In addition, I am thinking of tyring to REmap the ECU using the pocket romulator and pocket programmer. I hope to have all the pinouts so I can wire everything in place.Mettler wrote:I have the documents relating to the wiring diagram for the Q45, and the VH45DE engine loom. The VH41 loom is (nearly) identical. What specifically do you need ?
Just some update:doctorchee wrote:please give advise on this problems.
modify oil pan
or
modify and lower the cross member??
thanks
Help help please forward documents.Mettler wrote:I have the documents relating to the wiring diagram for the Q45, and the VH45DE engine loom. The VH41 loom is (nearly) identical. What specifically do you need ?
Haha its not a beast yet. Its in the making.... trying to gather all the bits required to make it work...Jesda wrote:I'm going to be in Thailand in July. I MUST SEE THIS BEAST!
