Audi White LED Daytime Running Lights - Sedan Version
General discussion area for the L32-chassis Altima
malnevets
Car: 07 Altima Majestic Blue
malnevets wrote:hey any1 know what the fuse and fuse holder is in place for in URSUS's original how to post? what if i wire it without the fuse?
nevermind, I figured it out =) how many amps you think a pair of thin LED strips use?
edonissan13
Car: Nissan altima 2.5s
To be honest i dont know the exact but i do know that LEDS use minimal power
malnevets
edonissan13 wrote:Im sorry i know im bugging now but i would like to know if u could take pics of it with the sun hitting it with the picture not so blurry?
well here are the pics that I was able to take. one of the pics have a penny in it, you could definitely fit one more penny there if you wanted.
SuBXeRo
ahahaha wow, i didnt realize u bought from oznium, i have been buying from there since oct 2003, its a great company with alot of wonderful products. woot. owner is a great guy too, i talk to here and there on AIM
edonissan13
i am extremely pissed da f*(&*O offfI got them in the mail today and got everything set up and one light doesnt f#$#$kn work !!!
edonissan13
Did dyou run into that problem wwhere one of them didnt work?
Because when i did the install one of them didnt work ?!?!
edonissan13
Dear Customer, Have you tried to rotate the wiring 180 degree and plug in again? Since the LED is polar sensitive, it means that of the power terminals are not matching correctly, the LED will not light up. (+ with + and - with -) Please go ahead try that and if the problem remains, let us know and we will exchange for you. For any questions or concerns, please feel free to contact us at anytime.
For any questions or concerns, please don't hesitate to let us know at anytime.
Thats what they told m e
malnevets
edonissan13 wrote: Dear Customer, Have you tried to rotate the wiring 180 degree and plug in again? Since the LED is polar sensitive, it means that of the power terminals are not matching correctly, the LED will not light up. (+ with + and - with -) Please go ahead try that and if the problem remains, let us know and we will exchange for you. For any questions or concerns, please feel free to contact us at anytime.
Yea you should test them before closing everything up. LEDs will work in one direction, if it doesn't turn on, then switch the wires and try again. This is usually the issue.Where did you buy the strips from?
Dun forget to post pics
Makavellimw
Car: 2007 Nissan Altima 2.5s
Hey Malnevets, thanks for your advice and instructions. I just installed the DRL today and here is how the project looks:
malnevets
Makavellimw wrote:Hey Malnevets, thanks for your advice and instructions. I just installed the DRL today and here is how the project looks:
your welcome. Looks sweet. which strips you buy? it seems to look like a neon tube style light from the pics.
P.S. i like your grille
Makavellimw
I bought the flexible LED strips from OZNIUM.com for $19.99 each. Hey thanks. I bought the grill from E&G Classic. What's your next modification?
skiski329
Car: Nissan Altima Coupe 3.5
how did you wire them to the fog lights?
Importroller
Car: G35 and 07 Altima 3.5 6spd
you can wire them to the foglight fuse
malnevets
skiski329 wrote:how did you wire them to the fog lights?
I just connected the wires form the LED strips to the fog light connection
they are the black and white wires comming out of the fog light itself
malnevets
Makavellimw wrote:I bought the flexible LED strips from OZNIUM.com for $19.99 each. Hey thanks. I bought the grill from E&G Classic. What's your next modification?
Man how much did you pay for your grille? I was selling mine lol
if I don't sell the grille, I will probably paint the inside bars of the E&G classic grille to match the car.
Then maybe some white interior led strips on the floors
eyelonfang
do you have any pics with the headlights on w/ the led strip on the headlights?
malnevets
eyelonfang wrote:do you have any pics with the headlights on w/ the led strip on the headlights?
Yea look herehttp://s367.photobucket.com/al...Strip/
Kango
Car: 2008 Nissan Altima Coupe 3.5SE
sorry to bump...
I just finished mounting the LED's.
Now... does it matter which end of strip you plug the wires in?
Ugh I suck at wiring. Mine are not working. ..... I tried plugging it other way... and it doesnt work. I guess I'll just wait till Sat and give it another shot.
Modified by Kango at 9:56 PM 4/7/2009
Modified by Kango at 9:57 PM 4/7/2009
scrutmonkey
Car: 08 Altima Hybrid
This mod took forever. i bought a set of he 19" strips from Oznium and followed the instructions posted on the TECH pages.
these LEDS strips. You just need to cut off 12 of the lights or 4 sections of "3." http://www.oznium.com/led-flex-strips
Getting the front bumper cover to line up and fit while squishing the led strips in between the cover lip and headlights was a PITA. but they look grat.
the wiring i ran around the bumper foam, soldered to the other strip nd through the firewall. I hooked the power wire into the cigarette lighter or power plug for full DRL effects. I also have the bottom LED strips too, might have to remove those, too many LEDS in the front looks weird.
UPDATE: 05/13/09So my lights started tripping out..
http://www.nissanclub.com/foru....html
i don't know if i'll reinstall them, but the good thing is Oznium is sending me a replacement for these 2. Anyone else have an issue with this type of strips where they are enclosed and completely waterproof?
Modified by scrutmonkey at 5:51 PM 5/13/2009
Importroller
Kango wrote:sorry to bump...
it doesnt matter which end you plug it into, but it does matter if the connector is upside down or not. so unplug it from the strip, and flip the wire, and plug it back in. There's a chance you had the positive going to the negative side
Kango
Thank you. I got it working. I didnt do LED under headlight housing... I did LED above fog lights. I tried LED under headlight but didnt like the way it looked when the lights were off so I used those LEDs for foot well.
I followed Ursus' diagram. (Pictured below)
I connect black wire to power and grounded black with white strip wire and it didnt work. So I just reverse the wiring and it worked. It actually looks better than I expected! Hehe thanks for help guys.,
khisanthax
I'm just curious if anyone has thought or tried using a photosensor in combination with the switch? This way it would be mainly turned on or off depending on the light but then a manual override can be used with the switch?
crayzitalian3
Car: 2007 Nissan Altima 2.5S
i bought the waterproof flexible silicone encased led strips and wanted to hook them up, but when i opened up the box today to check them out they had positive and negative wires on both ends of the led strip.
i went to hook it up to a 12v battery to see if it would work. i only used one side and they lit up all the leds.
my question is: would i be able to cut off the wires on one side or do i have to leave it there
Modified by crayzitalian3 at 9:46 AM 5/22/2009
crayzitalian3
i have another question.
i just hooked up the lights straight to my battery until my switch comes. my question is, the lights won't go off for some reason, even when the car is off, the lights remain on, do you guys have any idea why this happens?
scrutmonkey
crayzitalian3 wrote:i have another question.
It's because you hooked them up straight to the battery.
What I did was I ran them into the cabin through the firewall, and spliced them into the CIG lighter power.
crayzitalian3
how do you do that??
well i have a switch coming soon, so if anything i will wait.
i will still like to understand how you do that cause having the experience is always good.
Captain Canuck
Car: 2007 nissan altima 3.5se
where do you get these leds and what model are they they would look hot on my 2007 alt sedan. IT LOOKS HOOOOT.definitely a eye catcher
scrutmonkey
Here is the color for the CIG Lighter plug in the front of the console.
It'll be the only plug on the fuse block on thie diagram colord RED with a black strip. you just need to tap it, then connect a ground to a spot under the sterring wheel area.
crayzitalian3
how do you hook it up exactly? not sure how to do it
bimmer4life2009
eyelonfang wrote:looks hot! btw what model of the optiflux fogs did you get? i went on the website and there was a bunch.
Very informative thread thank you guys
Return to “4th Generation Altima Sedan (2007-2012)”
