JerodKing wrote:
I edited your post to only have the quotes I want in them. Since when does "do not appear" make it a fact? Hmmm...That sure sounds like they are making an assumption to me. Not fact. Same with found no correlation, making an assumption on the cases available, still not fact.
/discussion.
Modified by JerodKing at 8:40 AM 8/21/2008
It's a fact that no one has gotten lung cancer from marijuana. You cannot dispute this.
A link has never been found between Marijuana smoking and cancer. What this means is that smoking Marijuana doesn't raise your chances of getting cancer, any more than if you didn't smoke anything.
This is how scientific proof works: if there is no link found through studies, then one cannot say there is.... So since there is no link to finding lung cancer from Marijuana use... then it's safe to say it doesn't cause it. Numerous studies back this up.
The reason for this is because THC has anti-inflammatory properties, as well as Anti-Cancer properties. There is also proof that THC helps regulate cells, and keep them on their natural death schedule. Each cell has a set time limit that it's not supposed to over-live... cancerous cells break that limit... THC merely corrects this problem to some degree.
The Anti-cancer properties of THC, counter-act any cancerous effect the smoke may have. And of course, if you vaporize like I do or use edibles, then you've got nothing to worry about.
Here's a nifty link:
http://www.drugpolicy.org/marijuana/factsmyths/Quote »Myth: Marijuana is More Damaging to the Lungs Than Tobacco. Marijuana smokers are at a high risk of developing lung cancer, bronchitis, and emphysema.
Fact: Moderate smoking of marijuana appears to pose minimal danger to the lungs. Like tobacco smoke, marijuana smoke contains a number of irritants and carcinogens. But marijuana users typically smoke much less often than tobacco smokers, and over time, inhale much less smoke. As a result, the risk of serious lung damage should be lower in marijuana smokers. There have been no reports of lung cancer related solely to marijuana, and in a large study presented to the American Thoracic Society in 2006, even heavy users of smoked marijuana were found not to have any increased risk of lung cancer. Unlike heavy tobacco smokers, heavy marijuana smokers exhibit no obstruction of the lung's small airway. That indicates that people will not develop emphysema from smoking marijuana.[/quote]/owned
