Kerbear wrote:First time posting,I just bought a 2010 Rogue Krom and I have notice a shudder/vibration at 30-45mph on a common basis. Today driving home the car shook violently to the point that I had to stop. I pulled into a parking spot sat for a moment and then reversed, out it back into drive and it drove fine the rest of the way home. Now, the vehicle only has 700miles on it an the dealer said the vibration at 35mph was just the tires and the violent shudder was the rotors and they needed to be turned.....At 700miles on the car the rotors needed to be turned. Give me a break! So I look up any known issues with vibrations and it leads me to this website.
Hmmm... you didn't say when the violent shudder/vibration occurred. Let me first point out that kerrton made some excellent points. Yes it sucks you are having a problem with a brand new car... but Nissan will make it right.
That said... I'm a stickler for stuff like this. Regardless of the product, when I run into a situation like this I identify my concerns to the dealer or manufacturer or manager etc... and I "always" come out on top. I keep a level head, never raise my voice and always remain professional but they eventually understand I won't accept anything less than the best possible solution for me "the customer".
If the shudder/vibration you are describing occurs while you are braking then the dealer is probably correct on the problem being related to the rotors... HOWEVER... if that is the case... I "would not" let them turn them down! No way! Heck that's a poor solution for you the customer. Rotors "by law" can only be turned down X number of times as each turning cuts away at the thickness of the rotor surface area. At some point a cars rotors cannot be turned any further and will need to be replaced. If they turn your rotors now then there is a good chance you'll end up buying the next set when they really do need to be turned due to normal wear. There is "No Way" a new car with only 700 miles on it should need the rotors turned. If they determine your rotors are wrapped I would demand the rotors be replaced. If your car had say... 10 or 12 thousand miles on it then I wouldn't be happy the rotors needed to be turned but I wouldn't demand new ones. NET: On a new car with only 700 miles I want new rotors... not repaired rotors!
STOP! Let me back up. I need to clarify a point. FACT: A new car driven by someone using correct driving skills should never experience wrapped rotors in 700 miles. That said... could rotors get wrapped in 700 miles? Yes. It's a fact that some drivers bring on their own brake and transmission failures as a result of improper driving techniques. It is caused by drivers (who through bad or no training) learn to drive using their their right foot for the gas pedal and their left foot for the brake (and not using the right foot alone for both gas and brake). The tendency is for them to "rest" their foot against the brake peddle while driving. Unfortunately we've all seen them... cars driving down the road... keeping up with traffic but their brakes lights always on and or never going off or changing when coming to a stop. Because the driver is unconsciously riding the brakes all the time. In this situation the friction and the resulting excessive heat build up will warp rotors (not to mention put a heck of a strain on your transmission and tank your gas mileage. If you (or any other member of your family) drives with one foot on the brake peddle then the rotors could easily have warped the rotors in 700 miles. Understand I'm not implying your drive this way... just wanted to identify it as a potential explanation to a possible problem.
Next... if the shudder/vibration occurs when you are just driving long and not applying the brakes then it is NOT the rotors and could be anything from a loose wheel, bad wheel alignment, loose or defective tie rods or other front end linkage, a defective tire... and yes even a defective transmission. The good thing is, if they determine you just happened to unfortunately get a bad transmission (manure occurs)... then you'll be golden when they put in a new one. FACT: Every new product, from Honda Lawnmowers to Technivorm Coffee makers have a bad component once in a while. It doesn't make the entire mechanism bad... just the one part that needed to be replaced. Yes, its an inconvenience... but Nissan will make it right. The Rogue is an awesome car... don't give up on it and don't let this get you down.
Please check back with us and let us know what the outcome was and how it worked out.
