That's a very convincing post Kerrton.....well said.kerrton wrote:Couz,
There hasn't been a single complaint or issue reported regarding the upgraded programming. Everyone has said that they have noticed an improvement, some even reporting a major improvement.
The only negative reports have been related to service tech's making mistakes leading to issues, but the issue is with the human error, not with the upgraded software. As with ALL service work on your car, you run the risk of faulty workmanship, but any reputable garage will always correct mistakes and I'm sure Nissan is no exception.
And the most important point is that this is designed to prevent future problems with your CVT and reduce wear on your CVT. If you don't get the update, you could develop problems in the future or your CVT could even be experiencing unnessary wear and tear at this moment, we don't know for sure but all we can do is trust the Nissan engineers who are the ones with the knowledge, and assume that they have a very good reason for spending probably thousands of man hours and dollars to develop and test this softare, and recommend the roll-out to all Rogue owners.
This is a big deal, Nissan doesn't do this kind of a thing just for fun, you can be gauranteed that they had a VERY good reason for making this happen.
Sounds like the tech either tried to take a shortcut and screwed up, or was stupid and screwed up. Either way I haven't had my Rogue since before Christmas, and won't be getting it back until the middle of Feb.NissanTech50902 wrote:IdaCrue, there is no so called "Quirk" with the TCM on your vehicle. Every reprogram or "Update" as you guys call it require that a battery charger be hooked up to keep voltage above 12.5 volts. Reprogramming is done with Consult III (notebook) so once its hooked up to the DLC, it starts draining your battery. Thats with all TCM, ECM or any reprogram. Ive seen a tech try to do an update on the 02-06 Altima with no battery charger and fried the ECM.
Thanks for the advice Kerrton.kerrton wrote:Hey Couz,
My opinion is that 3 weeks delay is nothing to worry about, you've been driving it for many months without any problems so I'm sure it'll be ok for a few more weeks. Also, I don't think the CVT develops problems suddenly, based on past experience. If you are unlucky enough to get a bit of a rattle noise at low speed it develops over a period of months and even then, the re-program has been reported to eliminate the rattling. No need to visit the dealer twice in 3 weeks, I'd recommend doing it all at once, either wait 3 weeks or split the difference, schedule an appointment for next week and do your regular maintenance a couple weeks early, then you'll have peace of mind. Just my opinion!
