wd-40, hence the name, water displacement, 40th try.okinawa drift wrote:ahh ok, any techniques to get the water out? :P
judging by the relation to the clutch withdrawal lever that is the reverse sensor....plastic piece fits over the rubber cap on the sensor. if you look past the goo on my trans you can see it below. sorry, i haven't put in my 3 hours yetokinawa drift wrote:
does anyone know where the plastic peice on the ground goes??
what goes throught this loop?
no personal experience with this, but as he says 'better to be safe'. input on this anyone?verSat1l3 wrote:It costs a little more but I would fill it with Redline or Royal Purple gear oil. Make sure whatever you use is GL-4 compliant. The Advance Auto gear oil is GL-5 which some say has sulfites that eat yellow metals (your synchros). I used it once on a trans on its way out, and I think it accelerated the process... Who knows, its just better to be safe.
Gear oil, synrchomesh fluid, whatever, but NOT MOTOR OIL!! There are GL-4 and GL-5 gear oils, get GL-4. 2.4-2.5 liters worth through the shift column when the trans is in the car.okinawa drift wrote:when i go to pour in fluid into where the shifter would go, would i pour transmission fluid in there or oil??
and if im reading this right, are you guys recommending i use oil as transmission fluid?
also, if i were to go to a hardware store do you think they would be able to find out the bolts / washers i need if i brought my FSM with me? i know what page its on but im not really sure what "N * M" means
Throw out bearing is NOT a direct bolt on. You have to take out the old one from the sleeve and put a new one in. I saw it in one of your pictures earlier. You have everything, so just swap out the throw out bearing. Here's the write up. I ended up buying OEM throw out bearing BTW. If I'm wrong, you do have a bigger throw out bearing somehow. Let me know what's the case.okinawa drift wrote:also.. it turns out the clutch kit i have is wrong... and i traded my rc car for this clutch kit from a guy from portland, so i second hand bought it i guess you could say..
i could of swore the guy said it was for a sohc.... but it turns out the t/o bearing is to big, it wont slide onto the t/o bearing holder... where the last t/o bearing was...
Remove the seal on the shifter side and leave it like this for a couple of days. All the oil and stuff should come out. Yeah, I also had some shavings too. Shavings are okay, but chunk is bad, so you are good.okinawa drift wrote:
ken240sx wrote:wheel ramps in the rear with the e-brake on and jack stand in front for me.
