5 speed swap in progress!
okinawa drift
Car: 89 240sx SOHCoupe
well,well,well... i managed to get the sucker out!! i dropped the steering column completely, and pulled the brake booster as far out as i could... broke a coulple of the white brackets but oh well.. check it out
also i noticed the automatic brake pedal had two plugs... i know the blue one is for the brake light.. what is the other one for? my manual brake pedal didn't come with one.. do i need this plug? or can i live without it?
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
looking good...i am not looking forward to that part of my swap. the second sensor on the brake pedal is for the cruise control. without it, your cruise will not work. on another note, what paint and color did you use on the pedal brackets? was it straight up silver or something special?
kevin
okinawa drift
oh ok, yeah i don't need that then haha
oh and as for paint goes i used "silver metallic" you can get it from auto zone!
okinawa drift
also the plug that controls the brake light is really hard to unplug... hmm is there a special technique to unplug it?
heres a pic
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
plug should pull out easily if retainer clip is compressed properly...good luck
kevin
motoman399
Car: 98' wrecked (RHD coming soon) 240
okinawa drift wrote:also the plug that controls the brake light is really hard to unplug... hmm is there a special technique to unplug it?
i used channel locks... worked great.
94_240sx
Car: 94_240SX
Good job, okinawa. You are getting close. Spray some wd-40 and pull ot out as you pressed the retainer clip. One is brake light switch and the other one is circuit breaker for the cruise control. When you are on cruise control, it turns off if you hit the break pedal.
okinawa drift
thanks man:)ahh ok so i don't need that do i? since cruise control will no longer work
were you able to get your cruise control to work after a 5 spd swap?
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
moving right along man. your giving me hope when i do mine in the next month or so glad to see your taking your time and getting the proper information, it will pay off in the end.
puchuco
Car: 1995 Nissan 240sx
"""""Don't worry about the dust cover until trans is in, there is always a little slack in driveshaft so it may turn out to be correct. Also I put in a s13 trans into my s14 recently, I had the same identical dust cover,,they changed across some years. I had to pull it off and install my s14 dust cover.""""
I'm swapping my s14's transmission this weekend but, I'm missing the dust cover, how bad would it be if I just don't get the piece? Can I tweak my automatic one to get some protection?
Thanks!!!
94_240sx
Car: 94_240SX
puchuco wrote:"""""Don't worry about the dust cover until trans is in, there is always a little slack in driveshaft so it may turn out to be correct.
True, but it depends on how much slack you have. Car flexes a little bit, so you should have enough slack to clear it.
puchuco wrote:I'm swapping my s14's transmission this weekend but, I'm missing the dust cover, how bad would it be if I just don't get the piece? Can I tweak my automatic one to get some protection?
Thanks!!!
Yes, I modified s14 dust cover to use with 1 piece aluminum driveshaft. I cut and welded a stainless steel container to it.
ThuG LyFe
Car: 95 S14
looks good can't wait till it's done.
i got my 5 spd swap done and my CC works beautifully.
puchuco
I'm sorry , I thought you guys were talking about the bellhousing adapter plate/dust cover.
94_240sx
Car: 94_240SX
Thanks!!!
Oops!!! Sorry. Yeah, that thing is called dust cover or adaptor plate. You should install it otherwise your clutch might slip. I've seen a couple of people regreting it after they left it out. s13 dust cover is out of production, but s14 one is still available and will fit. You can buy one on eBay too.
http://cgi.ebay.com/ebaymotors...85489
puchuco
The one on ebay is for an SR20 and I have a KA24, would it still fit? (I doubt it)
okinawa drift
you guys think i would be able to get away with not re-surfacing the flywheel? since i just have a regular exedy clutch
S13.4
Car: 1991 Nissan 240sx SE
Dont Take That Bracket Out Or You Will Have The Clutch Pedal All The WAY down to the floor use those as guides and the measure the boot where the rod come out and use a hole saw that size....make sure you mark and center punch the center or you will run into problems for bolting up.... happy wrenching
a_ahmed
Car: 1991 240sx fastback
Hey guys,
I have s13 engine+transmission, earl ss soft clutch line, nabco master+slave cylinder, manual crossmember, engine/transmission mounts, even got shiftboot
I am just missing a non abs s13 manual driveshaft, hard line, and clutch/brake pedals...
Hard line can be fabricated... so its not THAT much of an issue but id prefer getting it... and well manual driveshaft... is there any real difference between the abs and non abs ones... my car is non abs.... and last but not least i saw some sale on that courtesparts nissan site that u linked to mentioning clutch pedal... but is it the WHOLE package EVERYTHING thats needed or?...
And is it necessary to get brake pedal assembly from manual? What's the difference?
So again
-Hard line-Driveshaft from non abs manual s13-Clutch and brake pedal assembly
Help
BMAR240SX
Car: 1993 Nissan 240S Coupe
a_ahmed wrote:Hey guys,
So again
Help
Cut your break pedal in half and do not waste money on putting in another one that is going to do the same thing.
a_ahmed
http://www.courtesyparts.com/b....html
Does this come with the whole brake and clutch pedal assemblies all together for 40 bux and everything needed? If yes I'll buy it, can someone chime in...
okinawa drift
no, usually a brand new clutch pedal will go for about $90ish
a_ahmed
so what comes with it.. i need the brake/clutch pedal assembly...
okinawa drift
search man, your jackin my thread..lol
anyways... would i be ok if i DIDN'T resurface my flywheel? since i have a regular exedy clutch kit
2ndnissan
Car: 1990 240sx hatch
Personally,I'd get it resurfaced. You've got it apart anyway and the new clutch plate will have a longer life and grip better with a flat plate. They develop hot spots even though they look flat. It's the same as a brake rotor...
okinawa drift
ahh ok, will do, im still debating on if i should get a new thermostat and new water pump for my ka24e while its out of the car... hmmmm
im most likely going to get a rear main oil seal for sure.. but thats probably the only seal im going to replace, since im on a tight budget
motoman399
okinawa drift wrote:search man, your jackin my thread..lol
if you are broke like most of us.. well at least me you can take some sand paper maybe 220 grit and just sand it a lil bit... it wont be perfect and i dont recommend this every time. also check for discoloration and dips and cracks. if you have any of those then get it resurfaced.
a_ahmed
Well im just asking its a simple question no need to be like you're hijacking my thread. Your thread is yours, woopie do man. Do you know, just answer... I didn't even know they were selling new ones.
2ndnissan
Water pump and thermostat are easy changes with it in the car. So those could probably wait a bit if nothing shows any sign of leaking yet and it wasn't overheating before. Rear main seal should be a definite "must do" while it's out. And check any rear freeze plugs.....
94_240sx
Car: 94_240SX
puchuco wrote:The one on ebay is for an SR20 and I have a KA24, would it still fit? (I doubt it)
Oops! Sorry. I didn't see it carefully. Anyway, buy s14 one from a dealership. It'll work on s13 & s14.
94_240sx
Car: 94_240SX
a_ahmed wrote:http://www.courtesyparts.com/b....html
No, it's just a pedal. Whole assembly is over $100. Try to get OEM hardline because you can't beat OEM hardline fitment. Make sure to get a bracket that goes between softline and hardline. You can buy Agency power stainless steel line, but I don't think the feel is as good as OEM hardline.
