spooled240 wrote:me and my dad do our own painting, we painted my bumpers, lip, sideskirts and wing and it turned out really good. It's not at all that hard, i mean you can definitely do it just looking at the patience and the quality of work that you've been showing us.
I'm not so sure. We'll see. Maybe I can talk somebody into helping out. Anyway...that's a way off.
Time for an update!
I had to move the Z around so I took a couple pictures outside. Another beautiful day in Ohio.
ZG flare fits good and I need to finish up the welding and install the nut inserts.
I am finding it easier to stitch weld along the edge with a copper backing plate and move around, trying to not let it get too hot.
I eventually got it everything done. Looks pretty good.
I purchased 13-32 nut inserts from Pegasus and a cool little tool to install. >> http://www.pegasusautoracing.c...TSERT
I did a trial install just to see what it would look like and if it would hold tight.
Not too thick when installed.
Almost flush, I'm happy
Here is one installed in fender. I used an epoxy while installing. Can't hurt.
At the forward corner, the inner fender was right up against the outer fender. I just drilled through the inner and installed the insert in-between the fenders. Looks good from the inside too.
OK...now on to the left side. Same lay-up using the 3.25" dimension (for top) and styling line for placement and try to follow original fender lip for the new flare.
Which puts me back to this point, but I keep looking on the other side to make sure it will be even.
That's it for today, tomorrow I cut and weld. I think the welding is pretty cool. I'll show you what I mean about using the copper backing plate when welding.
Gord
