Update, sorry it took so long...I started to work on the front end. The radiator and FMIC for now. I purchased a double pass radiator. That means the water passes through core twice. Once, from right to left on bottom, and then left to right on top. I picked it up 24" from Arts racemart. Very nice looking and hope it works.
http://www.randysracemart.com/prcdopara.html .
I used a floor jack to test out the height.
Also put the hood on and checked for clearance. Stuck my camera up and took a few pictures.
You might notice that I have cardboard on cooling fins. Keeps fins looking new during fabrication.
So I set the height and bent up some aluminum angles. Marked and placed them where I want them welded.
I thought I would give Defined Autoworks of Pataskala a try for my welding needs. I checked out their shop and talked to Logan, he said no problem and they did a nice job. So I got my rad back and just needed to trim and mount it.
I'm using grommets in bulkhead for rubber mounting.
Nice fit, everything looks good.
Now on to the FMIC
I purchased 24X12X4 intercooler on e-bay. X02 racing. Good price
I bent aluminum brackets and bolted to bottom of FMIC. The top is going to need some brackets made up. I ended up running out of time....
That's it for now... I'll pick up some sheet aluminum this week, and the tubing and couplings should be delivered as well.Gord
