spooled240 wrote:sorry if I missed this, but are you gonna paint the car?
Never would admit to painting a car. I do have somebody lined up, sort of. If anybody is interested, let me know.
AZ89two4Tsx wrote:What color are you painting the body?
Black or orange, just need to find the right orange. I keep changing my mind.
musashin wrote:I gotta be honest, cutting out so much of that support bracket really makes me nervous. It looks like you're taking all the strength of that structure out...
Me too. Im thinking about an external doubler welded around perimeter of opening. It is pretty thick metal, but it does flex when the transmission is moved around. I'll figure something out.
nuinqua wrote:Great job GMAC! Do your front wheels clear the fender when you turn?
No. Turning wheel "in" causes outside corner to hit.I need to do rear camber plates, section and weld new spring perch on struts, install stub axles, brakes, rear wheels and "drop". Then I can cut and install ZG flares should have good clearance after that.
