A little over a year ago I posted about a check engine light problem I was having with my Pathfinder (topic609078.html). I never ended up getting that far into repairing it on my own because I ended up having my entire exhaust replaced, and that seemed to take care of the issue. The check engine light was no longer coming on, and I was able to pass inspection. Now, I don't know whether the work done on the exhaust caused the problem to go away for awhile or if it actually fixed it. In any case, the light is back on. Since that post in May 2016, I have been able to get help on here to fix my A/C on my own (topic615123.html), and I have invested in some much needed tools. I just bought an OBD scanner, and I have read through the manual regarding my new issue. The scanner I bought is here (https://www.amazon.com/gp/product/B005Z ... UTF8&psc=1). I also bought an adapter to hook it up to my android, although I believe there is more functionality by hooking it up to a laptop and using the Windows software it comes with (obdlink.com/software). This is just some background information to let you know what capability I have. I thought having the scanner would make my life so much easier, however I can't find any information on how to use it, or what some of the readings I am getting mean.
The new issue I have is code 1130. In addition, the vehicle goes into limp mode (fail safe mode) when I use anything more than 2500 RPM's. At first I had code 1131 AND 1130, but after receiving the scanner, I cleared the code, wishfully thinking this might solve the problem (yeah, not so much). I did run a diagnostic before I cleared the check engine light, although much of it doesn't make sense to me. Almost immediately though, the check engine light came back on, and the limp mode never went away. I have both before and after diagnostic reports that I can show anyone interested in seeing them but I can't figure out how to upload them onto here. The 1131 hasn't come back as of yet.
So, I go to the manual and start to try to follow the diagnostic procedure for this code, and this is where I become lost. I have a multimeter and I am trying to follow the instructions on pg EC-520, but perhaps I am not testing the correct thing? Am I correct in thinking the voltage that I get should be equal to my battery voltage?
Another question I have is why the vehicle is going into fail safe mode when the codes listed are not ones (according to the manual) that should produce this mode?
Anyway, any direction would be helpful and greatly appreciated. Let me know if there's a way to upload documents onto here, and if people need further information. I know I was kind of all over the place, but I have spent so much time reading the manual, reading forum posts, and trying to do diagnostics myself but I am no further ahead than I was a couple of weeks ago.
Kristin
