Stupid question for your first post.drft4g63 wrote:I have an 89 240sx and a friend with a wrecked evo 8 i want to swap the ka for his 4g63 but i dont have any references to get help from have you done it or seen it done how hard is it ?
For the cost of fabbing everything up and custom fitting the engine you could swap two FWD SR20DETs from GTIRs into your 240SX making it AWD.drft4g63 wrote:I have an 89 240sx and a friend with a wrecked evo 8 i want to swap the ka for his 4g63 but i dont have any references to get help from have you done it or seen it done how hard is it ?
Its not worth it, just find a DSM and swap the motor into that.
No one. It hasn't been done, because its not worth it. Not only do you need a different transmission, you also need an intake manifold that doesn't face the firewall, an exhaust manifold that doesn't hit the steering linkage, motor and transmission mounts that not only hold the engine, but also line it up with the rear differential, a wiring harness that connects everything, an oil pan that clears the cross member, power steering lines that work, and a whole mess of things I'm not even thinking of.drft4g63 wrote: whos done it or seen it ?
You have no idea what you are dreaming up.drft4g63 wrote:ok... not helpful and i had an evo 8 with 350awhp just from a boost controler and fuel managment i know how easy it is to make huge power and i know setting it up longitudinaly requires either a different trans or blocking and plates plus a custom drive shaft the intention is to keep the 240 rwd with all the ease in tuning the 4g63 why would i want the to waste my money on rb or my time hustling 300hp out of the sr20
waste your money on an RB? HAHAHA! LOL! you really think that putting a 4g63 into a 240 is gonna be cheaper than swapping an RB? by the time and money you invest into making a 4g63 into a 240 work, you would already have 2-3 fully built rb 240s by thendrft4g63 wrote:why would i want the to waste my money on rb or my time hustling 300hp out of the sr20 whos done it or seen it ?
most likely nowhere. seriously. if this guy can prove us wrong, by all means do it.junjun0134x wrote:does sound interesting so i wanna see where this goes
No doubt, I see threads like this time and time again, and it is extremely rare that anything ever comes to fruition.apollas wrote:most likely nowhere. seriously. if this guy can prove us wrong, by all means do it.
That somebody was Ford, and I don't think you need reminding that Ford has very deep pockets.Sil40_Mayhem wrote:After somebody stuffed the 5.0L "Cammer" into that Focus a couple of years back, I'm not doubting much anymore.
You can tell 99% of the time when it would be possible. for example, the OP coming in here and asking a question like that, then you know its not going anywhere. if XS engineering, hybrid, or any other reputable company/shop posts something like this, id have second thoughts.FlatBlackIan wrote:
Thats actually not so easy either, all of the USDM DSMs came with the 4G as it was in the early model Evos. Then Mitsu switched things up, IIRC the Evo 7 was the first to use the revamp. It is still technically a 4G63T, but they flip floped which side of the engine compartment the motor sits in, while at the same time reversing the engines rotation direction to increase torque output. This makes swapping in to the older chassis very difficult.ken240sx wrote:Instead of putting the 4g63 in a 240...wouldn't it benifit you to find a cheap eclipse gsx or talon tsi shell....I mean it will be set up with an awd platform and I'm sure putting that engine in there wouldn't take very much effort considering that they came with let me see.....a 4g63 engine, so you probably won't need to fab much considering.
i dont think he is really looking into being "beneficial" here. hes just thought he could make cheap power by using the 4g with one of the cars he already had.ken240sx wrote:Instead of putting the 4g63 in a 240...wouldn't it benifit you to find a cheap eclipse gsx or talon tsi shell....I mean it will be set up with an awd platform and I'm sure putting that engine in there wouldn't take very much effort considering that they came with let me see.....a 4g63 engine, so you probably won't need to fab much considering.
If you want to be unique, find a twin turbo diesel that will fit in the 240 platform with some minor cutting and welding of the engine bay. Double the torque of a tuned 4g, and you can find one in a rwd platform.
