Just purchased a 169k 2001 Pathfinder SE 4x4 Gold with Black Leather Seats last week. PO had the car since new and became a seldom used 3rd vehicle. Vehicle lived its life in South Carolina and is pretty rust free body and paint is in pretty decent condition and has a sweet overhead lcd screen with VHS tape player OOOHHH. Work is going to be done at my brothers garage.
I love the forum! It has been a huge help already. Please take a look at my plan of attack and let me know if there is anything else i should consider or provide any words of wisdom from all you pathfinder experts. Plan is to keep this thread updated as i go.
Happy Reading!! -Kev
Issues:
-Suspension Shot
-Steering Shot, fluid pours out of rack
-Vibration going down highway, starts at about 50mph
-Tear on side of driver side and passenger seats in the vinyl portion by the electronic switches, leather is hard as cardboard on front seats
-Center Console Armrest is junk
-Rear View Mirror is junk
-P1110 code "Intake Valve Timing Control Bank", i believe mine is due to oil sludge
-tires worn out and dry rotted
-Rear Main seal leaking bad
-Oil Cooler Leaking
-Valve Covers Leaking
-Exhaust is nearly rusted through with one previous patch
-Anything underneath that was black for suspension stuff has a light haze of rust, body is rust free
-Step Bar is rusted from underneath
-AC doesn't work, recent records show has a leak
-headlights are hazy
-passenger side fog light has a small crack
-license plate bulb is out
-tachometer and temp dash light is out
-defrost button bulb is out
-Bose Cd player doesn't work, tape and radio work
-floor mats look terrible
-rear luggage carpet is in poor shape
Recent work performed by PO:
-New Alternator and belts 1 year ago
-New AC Compressor 2 years ago
-Front and Rear Brakes done ~25k ago
-some point in the past, Super Heavy Duty Transmission Cooler Installed, this thing is half the size of the radiator
Plan:
-Oil Change, with some transmission fluid to clean out some of the sludge, hopefully fix the P1110 code
-transmission fluid change - purchased
-Transfer Case Fluid Change - purchased
-Diff Fluid Change - purchased
-Brake Fluid Flush- purchased
-NGK Spark Plugs (considering doing coils, but they are pricy and currently they are fine)- purchased
-Coolant Flush- purchased
-All New Coolant Hoses- purchased
-New Radiator - ( while i am this far, it was cheap for a brand new Denso) The OEM radiator is really thin... - purchased
-New Thermostat (while i am there)- purchased
-New Water Pump (while i am there)- purchased
-New Rebuild Steering Rack (must do)- purchased
-Rebuilt CV Axles (while i am there) - purchased Detroit Axle
-Rebuild Driveshafts with new U Joints and Balanced Shafts - Rebuilt Carolina Driveline, Spartanburg, SC (awesome stuff)
-KYB Shocks/Struts- purchased
-2" spacer lift- purchased
-245/75-16 Cooper AT tires
-Front Moog Suspension Components, Lower Control Arms, Tie Rod Ends, Lower Ball Joints,
-Rear Moog Lower and Upper Control Arms- purchased
-Front Sway Bar links and bushings- purchased
-Key Fob - bought 2
-Used Armrest - ebay
-Used Rear View Mirror ebay
-Valve Cover Gasket and do Powervalves - purchased
-Seafoam treatment - purchased, done 2/9/17
-New Headlights - purchased
-Front Wheel Bearings- purchased
-Front Brake Pads, Akebono OEM, (Disc are in good shape)- purchased
-Remove Step Bar - done 2/19/17
-Air Filter- purchased
-Cabin Filter- purchased
-Fuel Filter- purchased
-Fuel Injector Cleaner, multiple treatments, 1st treatment 2/15/17
-AC Hoses, and replace all O rings, do dye test and see where it leaks after that. - purchased
-Duplicolor touch up paint - purchased
-OEM Nissan Floormats - purchased
-Would like to find a used black leather driver seat in good shape
-replace bulbs with leds
Work Completed:
-Seafoam Treatment from the spray can into the throttle body and fuel injection cleaner 2/9/17
-Put down first coat of Rejuvinator Oil from Leatherique, this stuff is awesome 2/9/17
-Washed her down head to toe 2/10/17
-Cleaned all the carpets, threw away the floor mats 2/11/17
-Installed led license plate lights, with SS screws 2/11/17
-Purchased some ratchet straps 2/11/17
-laid down a haze of penetrating oil on all the suspension nuts/bolts 2/11/17
-Cleaned off the Leatherque Rejuvinator Oi with the Prestine Clean, Leather is 10 times better. Rear seats are just like new soft seats, fronts are way better but need a couple more applications to be perfect 2/11/17
-Removed front driveshaft, u joints were shot, nuts where on there tight!! 2/12/17
brother tried to remove rear driveshaft, nuts/bolts were on super tight, brother cut open his pinky and needed 3 stitches, Major Ouch 2/12/17
-Removed Rear Driveshaft, took my bro an hour with torch and penetrating oil, with a busted up pinky 2/13/17
-Another Coat of Leatherique Rejuvinator Oil 2/13/17
-Valentines Day = no work
-Driveshafts rebuilt at Carolina Driveline in Spartanburg, SC, dang their shop is sweet 2/15/17
FYI rockauto has wrong part number for rear driveshafts. they list an outside locking u joint (Moog/National 269), but pathfinder requires inner locking u joint. Rear Part number = Neapco 1-0029, Front = Moog/National 446 These guys know their stuff
Big plans this weekend, Dad, bro and I are knocking a bunch out now that all my parts are here. let me know what else i should do!!
