Mounted up the new tires 265/65-17 Cooper A/T3 and a lot of the vibration went away. Found out my new u joints in my front driveshaft had about .020" of play and you could move it easily move it around. The driveshaft felt like you were getting a butt message and was worst at 48-52mph. Took out the front driveshaft and it drives very smooth. Finally figured out how to reset the airbag light. The youtube video and other posts in the forum on the method to reset it by pressing in the door switch 10 times didn't work. I ended up following the method in the Service Manual section RS and put it into self-diagnosis mode and by the blinks it gave me told me it had an issue but the issue is now fixed ( I ran the motor in the garage while the seats were removed, so the seat airbags were disconnected). I followed the Diagnostic Procedure as laid out on page 49 in the RS Section of the Service Manual:
Inspecting SRS malfunctioning parts by using “AIR BAG”
warning lamp — Diagnosis mode
NOTE:
SRS will not enter Diagnosis mode if no malfunction is
detected in User mode.
1. Turn ignition switch “ON”.
2. After “AIR BAG” warning lamp lights for 7 seconds, turn ignition
switch “OFF” within 1 second.
3. Wait more than 3 seconds.
4. Repeat steps 1 to 3 three times.
5. Turn ignition switch “ON”.
SRS is now in Diagnosis mode.
6. “AIR BAG” warning lamp operates in Diagnosis mode as follows:
After going into this mode the airbag light blinks will tell you the issue. You will need to use the manual to determine the code. I received 2 sec of the light off followed by 3 sec of the light on. This states that the code is still in memory but has not be erased following the repair (I plugged the seats back in). All you have to do next is turn the key to the off position and my light turned off.
New Tires mounted: 265-65-17 Cooper Discovery AT3 with a SFcreation.com 2" spacer lift
Can just bairly fit my finger between tire and KYB strut:
Took the truck into the dealer for an Alignment and perform the 3 recalls on the truck. The headlight and gas tank filler were all good so they didn't do anything. For the Strut Housing Recall I have zero rust but they stated they ordered some bracket and installed it. However I can't find anything of which they added in there...
Alignment Before: I used a tape measure to do a rough toe alignment and eyeballed the camber for the new camber bolts. Even though the caster is not adjustable I wish the Nissan dealer at least measured it.
After
Doing the audio install this weekend and wiring up an oil pressure gage.
