kevwa »
https://forums.nicoclub.com/kevwa-u75921.html
Mon Feb 04, 2008 3:59 pm
well i have been working on the wiring this past weekend and tonight - unfortunately i have a hacked up harness - i am positive i have a Series 1 b/c i have the igniter that mounts on the top of the valve cover by fire wall, and i only have 1 TPS plug, however, the harness came with some connectors cut off in the area where the MAF and O2 sensor plugs are. in this area of the harness i only have the O2 plug, and then there are just a bunch of cut off wire - i have been tracing them back through the harness and some of them are as follows; - pin 9 A/C- pin 25 boost control solenoid sig- pin 19 power steering oil pressure sw- pin 44 neutral switch- pin 8 which is not used- black wire with white stripe - splices into 4 wires - pin 109: inverse feedback circuit, pin 50: c/u earth, pin 60: c/u earth, and a white wire that goes to the white connector close to the ECU connector- pin 26 air flow meter earth (white with blue stripe)- pin 27 air flow meter intake air quantity signal (orange with blue stripe) pin 26 and 27 wires are in a separate black sheathing with a black wire whcih goes to the small brown connector looking thing by the ECU connector
based on previous reading on the forum i was under the impression that the series 1 was a 4 wire MAF green label J60, and the series 2 was a 3 wire connector with the color wires that i have on my harness hence i am stumped.
i hope all of this makes sense to some of you and that you guys can give me some feedback
thanks for the support on the project!
