Well since...two...of you already know about this, and its up on supraforums, i might as well put it up here...this is my build basially just copying and pasting from my other forums threads lol. My heads should be back next week, ill put pics up and all the head specs when theyre here. Lets just say 280+cfm, 9500+rpm...------------------------
Well as practically none of you know, my motor decided to let go on me on my birthday (december 30th). So its time to do the build. Expecting it to be finished in the fall, shooting for mid-high 800's to the wheels all boost...
Wesico 88mm pistons (.040 over)Eagle H-beam rodsPower Enterprise kevlar timing beltTomei 89mm 2mm thick headgasketsARP main studs/head studs
1mm OS valvesdual springsTi retainersJWT R5 cams (272/.385")5 angle valve jobP&P (flowbenched 280+cfm @<.400" lift)
Custom top feed fuel rail1000cc RC injectorsdual stock fuel pumps (parallel fuel set up through aeromotive FPR, full nylon braided lines)
AMS turbo manifoldsTwin Garrett gt3071r-wg turbos (.64 A/R)custom intake pipingcustom (Tom Green) FMIC w/full 2.5" piping3" Expansion downpipes with modified waste gate pipe to open dump3" - 2.5" coned test pipesHKS hiper 2.5" cat backSPEC tripple disc clutch
Rotora 6piston 14" front BBKGram Light 57s pro - gold with titanium rim (18X9/18X10)KSport RR coil oversST adjustable sway barsAMS front/rear adjustable camber armsAMS adjustable tension rodsAMS adjustable traction rods
AEM EMS w/map sensorAEM twin-fire ignition AEM injector driverSnow Performance water/meth injection
this is just a basic list, there will be a decent bit more in depth list as everything comes together. Ill update with pictures as parts come in
Anyways, for those who havnt seen it before here are some before pictures...
Video against a buddies 465+whp pullied cobra:
http://www.youtube.com/watch?v=HH-BFWngn58 (the video my gf took from my car)
http://www.youtube.com/watch?v=0JkyPxZq-6s (the video i edited that my friend filmed from the cobra)
just little videos after i put in the old cams:
http://www.youtube.com/watch?v=-2E0hp7s ... MgvaaZ1gfk
and heres how she sits now...
Ill take some nice pictures of how my pistons look from the motor that just blew lol. Detonation out the a**. Im thinking the timing belt slipped a tooth on the PS intake cam leaning the ever living hell out of that bank...
