Elton Noway wrote:I have a different question in relation to this update. While many have reported noticeable improvements... I'm worried about the possibility of negative effects and wonder if any members believe their Rogue is actually worse off after the update. BTW, I got the "Owner Notification" letter in the mail today.
"Nissan is conducting a Voluntary Service Campaign on certain 2008 to 2009 Nissan Rogues to reduce a subtle rattling noise that may come from the transmission at low speeds. On a small number of vehicles, possibly including yours, the transmission may make this noise." ... "To address this issue, your Nissan dealer will reprogram the Control Module and the Engine control Module on your vehicle, free of charge for parts and labor"
I've installed hundreds of firmware and software updates on computers, televisions, printers, autos, heck... I’ve even installed some on a few of the newer kitchen appliances. For the most part they always improve the operation of the item receiving the update... but in a few rare cases it has made the item so bad I’ve had to back off the update and revert back to the previous version. As you might guess this will be a little difficult to do since the Nissan dealership is the one with the updating equipment.
My concern is…my Rogue has never rattled, kicked, bumped, ticked or vibrated... at any speed. I'd sure hate for this update to introduce a problem considering I don't have any. I’m thinking … “If it ain’t broke don’t fix it”
As mentioned earlier by another member... its not a matter of requesting this transmission update because dealerships will most likely install the update on your next service call whether you ask for it or not since they get reimbursed from the factory.
Anyway… if after a couple weeks I don't hear of any ill effects in this forum I'll probably let the dealership apply the update and keep my fingers crossed the update doesn't introduce a problem to my perfect Rogue… (and hope they don't fry the module when attempting the update)
Also... several members have reported their Rogues are now zippy'er... after the update... i.e., more responsive to the gas pedal... quicker of the light. While this sounds exciting... I can't help but wonder how this might effect the miles per gallon.
Modified by Elton Noway at 11:40 PM 12/28/2009
Hi Elton... I was on the same boat as you... was a bit hesitant, because I had been PERFECTLY happy with how my Rogue drove (at least for the 4 months or so I've had it so far). In the end, when the dealer mentioned I should get that done, figured I wasn't gonna argue, in case the transmission breaks down later and it turns out I shoulda gotten the update when told to. Thinking there is a small chance the update might prevent some situations of mechanical wear or other other problems, but pretty much nil chance of the update itself producing problems. And there's the 10/100,000 to fall back on.
For what it's worth, I'm appreciating the update the more I drive, and no problems introduced by the update for me.
Let's stay tuned regarding the update and gas mileage... but I'm thinking the 2010s probably have this TCM/ECU setup and their mileage is the same, no?
