Zkyline wrote:I actually had a really hard time finding anything for the S2. But from what ive read the only thing you would need to change is the o2 and knock wiring. Thats what I did, (spliced o2 wires together, to the one on the RB harness, and then the two knock wires on the RB harness to the one on the z32) runs fine, no CEL Yet.
I saw it on the nistune mod instructions for when I get my type 2 board. In the ECU pin out for the RB to z32 ecu you take out pin 36 and put it into pin 33. I take it pin 33 is no longer needed? But in their instructions its only for series 2 rb25Zkyline wrote:I have 3 conflicting diagrams. One lists that as orange, another as lt. Green. And yet another that says pin 104: ? Lol. Did you do the fuel temp resistor mod? I didnt bother doing it.
Zkyline wrote:I tried several resistors (for different temps), didnt seem to make any difference. I imagine if you wanted it to read correctly, or at a "set" value for tuning reasons it may be important. I am going to run a APEXI SAFC piggyback fuel controller, once I put my Holset on, so I kinda started ignoring some of the Nistune steps. Lol
NolimitZ32 wrote:CX Racing doesn't have the best reputation for good fitment but other than that it looks like a pretty awesome deal. To make the system work efficiently you need to make sure there is a draw out for the Intercooler and the radiator which the car is not designed for, its something you'll have to do yourself, not too difficult if you are handy though, just something to think about.
NolimitZ32 wrote:The issue with having the vent in the nose panel may be that during high speed you'll be counteracting the flow. I can't say whether this is actually true or not since I've never seen this car in a wind tunnel especially with an aftermarket nose panel but its something to think about.
NolimitZ32 wrote:That wind tunnel video does absolutely nothing, you need to be able to see how the airflow behaves at the nose panel with the v-mount setup in place and different types of nose panels. As for open flow into the engine bay, you aren't creating a pulling effect, you are causing a blockage because once the air enters through the v-mount it stagnates in the engine bay as there is nowhere for it to go. And all areas where the air could potentially exit from the engine bay are surrounded by fast moving airflow creating a high pressure and encapsulating the air within the engine bay. This is why all the properly built v-mount setups you see have a pretty outrageously shaped openings in the hood and ducting. What has to be done is an area of low pressure has to be created where you want the hot air from the inter-cooler to go, this will effectivelypull the airflow through the inter-cooler increasing efficiency. Read through this to get a little better understanding http://ateupwithmotor.com/terms-technol ... od-scoops/ Now keep in mind, not doing any of this and just sticking the setup in as is wont have detrimental effects especially if you install fans., what I am talking about is achieving maximum efficiency of the system.
