[/url]I use those fittings at work on pneumatic equipment which run on 100psi of air. Very easy to work with and disassemble. They are called push to connect pneumatic fittings.JayNoel wrote:Anyone ever try this setup for breather tubes 20mm 2.5 thread push hose coupler for hi psi air line? Trying to clean up the motor
Thanksgrayman_TT wrote:I use those fittings at work on pneumatic equipment which run on 100psi of air. Very easy to work with and disassemble. They are called push to connect pneumatic fittings.JayNoel wrote:Anyone ever try this setup for breather tubes 20mm 2.5 thread push hose coupler for hi psi air line? Trying to clean up the motor
Keep up the great work.
Wiring Specialties wrote:Looks like a great project. We just launched an plug and play wiring harness for this swap if you are interested in replacing the original wiring harness.
Check it out: http://www.wiringspecialties.com/rbwihafor30p.html
Ace2cool wrote:Quick progress in here for such a cool build!
Yeah I got flat black av-09 avids. I sold my only set of wheels and needed something for now. fronts are 18x9.5 +38 and rears are 18x10.5 +22. still gotta see how they line up but its been too coldDCaff300ZX wrote:Yeah, not so sure those wheel sizes they have will fit a Z32 so well, very limited sizing more like a clearing house.
If I buy inexpensively I like to see the same sizing options as any other time or my Red Flag goes up...
Give Charles a call anyway, they often have a set or two left over and may still work you a deal especially if you get the adjustable bits as well, which is beyond recommended...JayNoel wrote:Also looking for a set of coilovers... Kinda mad I missed the powertrix sale :/
